August 18, 2014, 09:05 |
Report of moving average
Reine Granström
Rep Power: 17 |
Hi all,
Is there a way to calculate a moving (rolling) average using a regular "Report monitor" within Star CCM+? I am looking for an alternative to exporting the monitor data and calculating the moving average in a third-party software like Matlab. Cheers, gravis |
August 20, 2014, 07:33 |
Lane Carasik
Rep Power: 15 |
If you have access to the Steve portal, there is a specific article discussing making a rolling average for a field mean monitor. Make field mean -> Enable Sliding Window Average -> Insert number of iterations or time steps
Hope this helps. |
August 20, 2014, 09:16 |
Reine Granström
Rep Power: 17 |
Many thanks. The thing with the suggested approach is that a rolling average would be calculated in each cell. What I wish to do is to calculate a rolling average of a global scalar from a relatively large number of samples. As the number of samples grows for a rolling average of a field mean monitor, the simulation file size could become impractically large as the solution should be stored in all cells for each sample.
y+ and u+ values with low-Re RANS turbulence models: utility + testcase | florian_krause | OpenFOAM | 114 | August 23, 2023 06:37 |
Floating point exception error | Alan | OpenFOAM Running, Solving & CFD | 11 | July 1, 2021 22:51 |
How to obtain turbulent kinetic energy data from LES model of Ansys CFX? | rsin | CFX | 19 | December 29, 2018 05:43 |
[snappyHexMesh] jagged, ragged edges... | ziemowitzima | OpenFOAM Meshing & Mesh Conversion | 138 | July 24, 2012 00:41 |
[Other] How to set up a dynamic mesh for a piston moving through a tube of variable diameter? | karkar | OpenFOAM Meshing & Mesh Conversion | 0 | July 4, 2012 07:54 |
