Errant Velocity Vectors in Rotating Reference Frame Prop Sim
Old   August 17, 2014, 15:18
Default Errant Velocity Vectors in Rotating Reference Frame Prop Sim
Muzz is on a distinguished road
I'm trying to simulate the induced velocity of a micro-UAV propeller operating in open air. I followed the exact same procedure in the Star-CCM+ documentation with a boat prop in open water but changed the conditions accordingly.
For the most part, the flow through the rotor makes physical sense but there are some strange velocity vectors that shouldn't be there. I've attached the following images: scalar scene of velocity magnitude; vorticity isosurface; residual plot; vector scene in XY and YZ planes.
You'll see that for the scalar velocity scene, I had to set the max velocity to 12m/s, but the auto max value is 51.6m/s. The vector scenes should highlight the problem best. Of course, we expect most of the flow to be induced in the negative Y-direction so I don't know where these large vectors are coming from.
Is it a convergence issue? I know it could be a bit better but I thought the residuals were acceptable.
Muzz is offline   Reply With Quote
Old   August 21, 2014, 11:22
Ping
ping is on a distinguished road
no sure what you are saying here - is it that you dont expect to see velocities higher than 12 and why are they present or how do you change the display in the legend to set that max to 12
ping is offline   Reply With Quote
Second Derivative Zero - Boundary Condition fu-ki-pa OpenFOAM 11 March 27, 2021 05:28
Boundary Layer Single Rotating Reference Frame john c FLUENT 0 April 22, 2013 19:11
Different solutions for Rotating Reference Frame fafou09 FLUENT 1 July 24, 2012 11:06
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 13:38
Gravity in single rotating reference frame QinxueTan FLUENT 0 May 7, 2008 07:59
