Generalized Cylinder Mesh and Element Clustering
Old   August 12, 2014, 14:14
Default Generalized Cylinder Mesh and Element Clustering
Matt
fluid23 is on a distinguished road
I am currently working my way through the tutorials contained in the Star-CCM+ help material (and saved under \doc\startutorialsdata in the installation directory). I am working the 'Steady Flow-Laminar and Turbulent in an S-Bend' example which illustrates the Generalized Cylinder Mesh tool. However, the mesh that is generated does not resemble the mesh shown in the tutorial (pg 8400 of the pdf). The screenshot in the tutorial shows that the curved regions of the pipe have higher element density than the straight sections. My generated mesh is the exact opposite and as far as I can tell I have followed the directions exactly. My questions are:
1. Given that the mesh tool is optimized for circular pipe flows, do I need to worry about decreased fidelity in curved regions as compared to straight? The scalar plots look identical and the only discrepancy in the vector plots appear to be density/locations of the vectors which seem to be linked to cell location.
2. Is there a way to set the clustering of these elments so that they occur in regions with curvature rather than straight regions? I played around with changing the Extrusion Law to Symmetric Hyperbolic Tangent with some limited success but I was unable to get anywhere close to what is shown in the tutorial. I also managed to crash the software doing this, FYI.
I am running v9.02, if that makes a difference. See attached image for further details.
Thanks in advance.
fluid23 is offline   Reply With Quote
Old   August 21, 2014, 11:37
Ping
ping is on a distinguished road
it looks to me like they used another mesher for the image and i agree that the cylinder mesher cant do that at present
you can get close to that by spliting your pipe into 3 separate wall boundaries by using imprinting in 3d-cad then apply different constant pipe extrusion parameters to each wall
ping is offline   Reply With Quote
Old   August 27, 2021, 08:48
Default extrusion of generalized cylinder mesh
Viktor Klüber
ViktorKL is on a distinguished road
The post under this link shows how to apply the generalized cylinder mesh and extrude from the interface.
ViktorKL is offline   Reply With Quote
cylinder mesh, element clustering, star-ccm+
[Other] Mesh Importing Problem cuteapathy ANSYS Meshing & Geometry 2 June 24, 2017 06:29
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
autoPatch error, mesh quality related...? Alexvader OpenFOAM 0 October 6, 2011 18:57
ICEM clustering of mesh points and multiple edges webhaw CFX 4 July 25, 2007 17:29
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
