Visualization: a plane that follows building shape
Old   August 10, 2014, 15:35
Default Visualization: a plane that follows building shape
Djordje
djordje8 is on a distinguished road
Hi all,
I've completed a simulation for an urban block. The buildings are presented as cubes. Now, I would like to see the velocity at 5 m above building tops, walls and roads. Therefore, I need to create a plane that would envelope that part of the computational domain (the part with the buildings), but the plane should be 5 m above the bottom/surface.
Please do you know how could I approach this problem?
Thanks,
DjR
djordje8 is offline   Reply With Quote
Old   August 11, 2014, 08:06
kris
kguntur is on a distinguished road
You could create a part that represents your required plane by duplicating and repairing existing geometry. Then use that plane to create an arbitrary section.
I know that in 9.02 you can create an arbitrary section from a part directly. In older versions, you have to export it as stl and import it as an arbitrary section.
Hope this helps.
kguntur is offline   Reply With Quote
Old   August 11, 2014, 10:32
Djordje
Thanks. I'll try this today.
buildings, velocity field, visualisation
[foam-extend.org] Error compiling OpenFOAM-1.6-ext Canesin OpenFOAM Installation 137 January 20, 2016 15:56
[ICEM] cut plane visualization Will Anderson ANSYS Meshing & Geometry 12 August 26, 2015 15:20
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
Compilation error OF1.5-dev on Suse10.3 darenyang OpenFOAM Installation 0 April 29, 2009 05:55
