Error "Attempt to access unallocated Volume FractionLevel1 in cells in Domain"
Old   August 2, 2014, 11:48
Default Error "Attempt to access unallocated Volume FractionLevel1 in cells in Domain"
Mohammed Gowhar
mdgowhar is on a distinguished road
Hi all
I have rectangular domain. In which i have setup my case with two sliding meshing and 4 overset mesh. I have initialized the Overset Interface and Sliding Interface. It successfully created cut in the background mesh for the overset.
And initially im trying to run this case for laminar once if its successful i can turn it for Turbulent.
i gave the physics and initialized over all domain with 0 Pa Gauge Pressure and 111m/s for free stream velocity and propeller is rotating at 2500 rpm. Implicit time stepping of 0.001s and 5 inner iterations.
The problem i face when i start my iteration i get an error tat
"Attempt to access unallocated VolumeFractionLevel1 storage in cells in Domain"
i have attached the image of the mesh
Please help me on this..
Thanks in advance.
Cheers
mdgowhar is offline   Reply With Quote
Old   August 4, 2014, 00:54
me3840 is on a distinguished road
Check that all of your solvers are unfrozen and that your solution is clear
me3840 is offline   Reply With Quote
Old   August 4, 2014, 10:31
Mohammed Gowhar
I have checked all my solvers. It is unfrozen. Any other way to troubleshoot this problem.
Old   August 4, 2014, 10:43
Default My Domain
Mohammed Gowhar
I have attached my domain region.. Its rectangular box in that i have subtracted a sphere. Hence i can use sliding mesh there.
Old   August 4, 2014, 21:02
If this is an external aero problem, your mesh is far, far too coarse to get a good answer.
What are your physics? Volume fraction implies you have a multiphase model selected. Make sure that isn't the case.
Old   August 5, 2014, 01:53
Mohammed Gowhar
Yes.. this is an external aero problem.
I have used implicit unsteady, segregated flow, constant density and laminar as physics.
Old   August 5, 2014, 02:08
Well, let's start disabling things to see what is broken. Get rid of the overset interfaces and see if it initializes then.
But you should really review your mesh, it is not adequate.
Old   August 5, 2014, 09:12
Mohammed Gowhar
I will try and report you tomorrow. because total mesh size is 13Millions cells.
Old   December 12, 2018, 09:09
Kushal Puri
Kushal Puri is on a distinguished road
[QUOTE=mdgowhar;504157]Hi all
Thanks in advance.
Please share if you got the solution for this
Kushal Puri is offline   Reply With Quote
overset mesh, propeller, sliding mesh, starccm+
[ICEM] error analysis despaired student ANSYS Meshing & Geometry 7 June 27, 2012 12:57
About negative volume of cells! xhliu1 Siemens 0 April 16, 2005 00:49
Volume of cells vince CFX 10 August 15, 2003 18:03
Minus Volume of cells di bonga CFX 2 April 8, 2001 14:38
