Heat transfer solid-fluid: how are the two heat balance equations connected?
Old   July 25, 2014, 06:27
Default Heat transfer solid-fluid: how are the two heat balance equations connected?
Fritz is on a distinguished road
Hey guys, this question has been bothering me for a long time and I just cannot get a answer to this:
I am wondering how star-ccm+ connects the two heat balance equations if a conjugate heat transfer problem is modeled , say conduction heat from a fluid to a solid wall.
Is it usind the "direct coupling" method, solving both equations simultaniously after having connected them through the assumption that the temperature or heat flux are identical at the phase-boundary,
OR
does it solve each equation in turn and take one sides result as a boundary condition for solving the heat balnce equation on the other side in the next step? And if it is that case here, does it use the same solver?
I hope someone of you guys can help me out since that question has been bothering me and I could find no answer!!
Thanks alot in advance!
Best,
Fritz
Fritz is offline   Reply With Quote
cht, cht coupling, direct coupling, solver
Help needed in meshing for Solid to Fluid Heat Transfer niazaliahmed FLUENT 2 February 22, 2020 16:47
heat transfer coefficient for the fluid / solid interface sarah l Fluent UDF and Scheme Programming 15 May 18, 2016 09:28
modeling heat transfer betwwen fluid and solid Al Mazdeh CFX 0 March 13, 2008 11:35
Conjugate Heat Transfer between fluid and solid Li Yang Main CFD Forum 8 March 27, 2004 12:05
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
