July 24, 2014, 08:01 |
Measuring pressure on a rotating surface
Stephen O'Donnell
Rep Power: 12 |
Hi Everyone,
I'm simulating a helicopter rotor. As the blades rotate around a shaft axis they also morph (change in pitch). Can anyone tell me how to measure the pressure on the surface of a blade at 87% along the blade while it rotates. |
July 25, 2014, 03:13 |
Gajendra Gulgulia
Rep Power: 13 |
you can take mass flow averaged pressure report and assign the blade boundaries before you give the run and also create a monitor plot for the same.
July 25, 2014, 18:35 |
Rep Power: 25 |
I think his question was more pretaining to the 87% blade distance issue. If that's the case you can make a circular section cut from a derived part and only select the blade surface as the input. That should make just a 'ring' going around the blade at a specific radius.
July 26, 2014, 15:14 |
Stephen O'Donnell
Rep Power: 12 |
Thanks. That seems perfect. How can I export the pressure measurements?
July 27, 2014, 22:26 |
Rep Power: 25 |
Export them for what?
July 28, 2014, 15:08 |
Stephen O'Donnell
Rep Power: 12 |
To create graphs in Matlab
July 28, 2014, 18:56 |
Rep Power: 25 |
In that case just monitor the report and plot it, and you should be able to export the plot as a table.
July 29, 2014, 07:24 |
Stephen O'Donnell
Rep Power: 12 |
Thanks. You have been a big help.
morphing motion, pressure, pressure contour, rigid body motion, unsteady ; rotating |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 08:54 |
"Pressure Inlet" Boundary Setup | Wijaya | FLUENT | 15 | May 18, 2016 11:08 |
getting negative static pressure on airfoil surface | rishad | FLUENT | 4 | July 15, 2014 15:27 |
Calculating forces on a non-closed surface | ScottN | FLUENT | 0 | March 1, 2011 18:18 |
rotating frame of reference and total pressure | viking | ANSYS | 1 | November 24, 2010 00:25 |
