July 16, 2014, 07:16 |
orthotropic viscous resistance
hi i want add orthotropic viscous resistance in the downstrean duct of fan for the calclation of pressure drop Kindly guide me at what distance should i create this resistance, should I put at the end of the downstream duct .
As far as I know I have to give value in the porous viscous resistance |
July 17, 2014, 02:32 |
Rep Power: 25 |
You can enter in a porous inertial and viscous resistance, but they should be calculated based on a porous media's pressure loss response to a certain velocity field.
If you punch in the tensor type as axisymmetric tensor you can define a streamwise and cross-stream dimension which will suffice for your orthotropic resistance. |
July 17, 2014, 03:55 |
hi
Thanks for your guidance how can I find these values is there any specific formulas for that, the value I have to give as a axial component is the pressure drop with respect to the volume flow rate or velocity in the fan curve that I have.
Thankyou so much for your precious time |
July 18, 2014, 00:35 |
Rep Power: 25 |
Pressure drop on a fan curve? That doesn't make any sense. Fans put energy into flows. The pressure should rise.
July 18, 2014, 02:57 |
hi
I am sorry I mean I have curve pressure rise vs flow rate so should I put Pressure rise value in the axial component value with respect to mass flow rate I am giving at the inlet ? and I put this resistance at the end of the downstream duct in the z-direction because my duct is along z-direction just before the pressure outlet is it ok ?
July 20, 2014, 23:23 |
Rep Power: 25 |
I'm still confused. What does a porous media have to do with a fan? They do different things.
July 21, 2014, 03:50 |
hi
actually i am trying to create a fan curve at different flow rates so for that reason i put some resistance at the end of downstream duct but its not really work i think and now i am just focusing on what you told me i made exruded duct on both side of the fan and boundary condition i am using is pressure outlet as inlet and same for outlet. I just fixed the pressure specification to total pressure (0.0 Pa) at inlet and outlet to static but i am confused what value should I give at outlet I just have fan curve from the manufacturer. I am measuring the massflowrate total and static pressures at 10 times of fan dia.
Viscous resistance coefficients in porous medium | fpingqian | FLUENT | 50 | June 26, 2019 02:55 |
Inertial Resistance and Viscous Resistance Data | ravitejakatragadda | FLUENT | 5 | May 10, 2018 05:16 |
Viscous and Inertial Resistance in Porous Media | aulu | FLUENT | 0 | September 14, 2011 06:21 |
how to calculate the viscous and inertial resistance coefficients? | omurakbayir | FLUENT | 1 | November 22, 2010 23:36 |
adapt viscous resistance based on velocity / UDF | Häwimeddel | FLUENT | 2 | April 20, 2009 11:08 |
