July 14, 2014, 16:08 |
VOF - Interface between regions
I am setting up a VOF simulation of an open channel flow problem, and have defined two regions: water and air (both are rectangular). At the inlet, I am using velocity inlet and setting the relative concentrations (100% H20 for water region; 100% air for air region), and pressure outlet for both. I am using a flat VOF wave and defined the necessary water and air velocities, density and the H2O surface elevation at the inlet.
What type of boundary should I use for the air-water interface along the length of the channel for my boundary condition? This corresponds to the flat water surface air-water interface at the beginning of the simulation, however, the free surface will change and develop small waves during the course of the simulation because of a surface-piercing cylinder. Thanks in advance for any input. |
July 15, 2014, 11:07 |
Ping
Rep Power: 20 |
you don't need two region for this so just have one region - do the vof tutorials to understand how
you can complicate the model with additional regions and the interface will be an inplace one to all flow of both air and water depending on where the free surface is |
boundary types, free surface flow, open channel, vof model |
Length of interface in VOF | IndrajitW | FLUENT | 4 | April 17, 2019 05:44 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
VOF no interface | Mat_fr | Fluent Multiphase | 2 | June 11, 2013 10:52 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
