Fan simulation with inlet and outlet duct
Old   June 27, 2014, 09:59
Default Fan simulation with inlet and outlet duct
hashim chaudhry
chaudhry_hashim is on a distinguished road
Send a message via Skype™ to chaudhry_hashim
Hi, I am working on a simulation of axial fan with inlet and outlet duct in order to investigate the pressure drop across the fan. My fan Dia is 116 mm and i made the inlet of 300 mm, outlet of 500mm. I am using moving frame refernece for this case in which i am giving fixed rpm to a rotating region with velocity inlet and pressure outlet. The issue is whenever i run the simulation reversed flow occur and after few iterations it shows the error of floating point overflow/ kturbukence.
I am using surface remesher, segregated flow and polyhedral mesh as a mesh condition and steady, constant density with kepsilon turbulence model. I also attached the pictures of geometry, pressure and velocity results.
Please help me out I would be very thankful to you
Regards
Hashim
chaudhry_hashim is offline   Reply With Quote
Inlet and Outlet BC for maximum flow of a radial fan nash OpenFOAM Pre-Processing 0 October 24, 2013 04:44
inlet and outlet BCs for airfoil simulation michel1988 OpenFOAM Running, Solving & CFD 2 July 9, 2013 12:12
define BCs at inlet and outlet for natural ventilation simulation jjz2013 Main CFD Forum 0 January 29, 2013 16:50
Inlet shapes for modelling a fan in an inlet duct buzzybee CFX 10 June 11, 2009 21:15
Periodic BC on Inlet and Outlet of a Duct Steve CFX 2 August 8, 2005 13:03
