June 19, 2014, 12:09 |
Negative mass flow rate
Lokesh
Rep Power: 12 |
I am trying to check mass flow rate and am getting negative mass flow rate. For the same model if I am changing some boundary conditions such as pressure values I am getting positive values for some conditions. Why is this happening? What I have to do if I get negative mass flow rate. |
June 19, 2014, 17:26 |
Rep Power: 25 |
Negative mass flow rates just means the mass flow is going against the normal of the face of whatever you're measuring it on.
If you change pressure on the boundary conditions it's possible to reverse the direction of the flow. You seem to be confused by something pretty fundamental. What are you trying to find out? |
June 19, 2014, 18:12 |
Lokesh
Rep Power: 12 |
Thanks for the reply. I am learning star ccm+.
I have modeled a body in which I am trying to give primary inlet pressure, secondary inlet pressure and exit pressure. I am checking for mass flow rate convergence. There for some boundary conditions I got negative mass flow rate. |
June 20, 2014, 15:47 |
Rep Power: 25 |
That doesn't sound unreasonable. In general high pressure flows to low pressure. For certain pressures on your BCs it's possible for the flow to reverse direction. What's the problem?
mass flow rate, star ccm+ |
Mass flow rate at the outlet | tejasvikrishna | FLUENT | 2 | May 25, 2013 03:42 |
Mass Flow Rate is not converging | destgir448 | CFX | 5 | December 11, 2010 06:55 |
Mass Flow Rate | student87 | CFX | 4 | January 2, 2010 05:45 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
mass flow rate error | Masood | FLUENT | 0 | May 22, 2005 01:32 |
