Leakage simulation
Old   June 10, 2014, 04:42
Default Leakage simulation
Jishen Zhang
Romarius is on a distinguished road
I'm simulation a compressible pipeflow between two high pressured tanks and there is a leakage in the middle of the pipe and I know nothing about the form of the leakage section but the pressure drop (dp/dt).
So is there any way to simulate that leakage?
Jishen
Romarius is offline   Reply With Quote
Old   June 10, 2014, 09:36
Ping
ping is on a distinguished road
it seems to me that you will have two sources of pressure drop in the pipe - from friction and the hole and I hope you know the mass flow from tank to tank
so if the tank to pipe junctions and the pipe are modelled well then the only unknown is the hole area and its shape
by assuming a simple circular hole you could run a series of cases with different diameter holes and home in on the size that gives the correct pressure drop between the tanks
ping is offline   Reply With Quote
Old   June 10, 2014, 14:45
Jishen Zhang
Thanks for your answer!
Yes I know the mass flow and the surface of the section but I have no idea of what the form is but anyway the section is very small (2.4e-03 mm2) so that would be very hard I think to mesh the local. I've heard of a kind of a cell that you can put into the place and it will play the role of a sink.
Old   June 12, 2014, 05:27
Ping
creating small cells of that size is not a problem - just use a volume control and slow growth and have at least say 10 cells across the opening and a volume of cells on the outside to exhaust into with a pressure boundary condition at some distance away
if you add the hole and outer volume in 3d-cad you can then easily change the shape of the hole if you want to explore other geometries
Old   June 12, 2014, 12:04
Jishen Zhang
Ok, I will try it, thank you!
Why my simulation not agree with the wind tunnel experiment zhaowei CFX 4 July 11, 2015 04:36
Solar Radiation in OpenFOAM plainstyle OpenFOAM Running, Solving & CFD 15 July 8, 2014 05:43
problem in sealing inter chamber leakage in wankel simulation pravin.iitk FLUENT 1 August 18, 2011 11:31
Simulation of a complex wing in solidworks flow simulation niels1900 FloEFD, FloWorks & FloTHERM 6 April 20, 2011 11:44
strange simulation error Ralf Schmidt FLUENT 2 May 4, 2007 14:02
