Overset Mesh error : no startcell found !
Old   June 5, 2014, 06:24
Default Overset Mesh error : no startcell found !
Cristina Zaragozano
Cris ZC is on a distinguished road
Hello everyone,
I am working on an Overset mesh simulation.
I don't know how to create an overset mesh situation from zero, so i experience it on simple parts created in starccm.
I have created a cubic background region (with one free stream boundary), then a cubic overset region with a wall sphere in it.
The wall sphere is the physical item on which is applied the free stream.
To be more precise on the overset region, the wall boundary is the sphere, and the overset boundary is the subtract between the sphere and the overset block.
When i mesh everything with surface remesher, polyhedral mesher with the same base size in both regions, it works.
When i initialize the solution after creating the overset mesh interface, i get the following error :
Updating indirect region interface Overset Mesh 1 between Overset and Background.
Failed to create Overset Mesh Interface between Overset and Background: no startcell found !
Command: InitializeSolution
CompletedCommand: InitializeSolution
error: Server Error
I have searched on the internet and found absolutely nothing on that error. Would somebody know some clues on how to solve that error please?
If you have any questions let me know
Thanks,
Cris
EDIT : It appears that the inside of the sphere is also meshed. And of course we don't want it. Maybe that's because we include the sphere as a part for the continuum mesh. But if we don't include the sphere, the sphere doesn't exist for the physical simulation so that's not what we want either
Cris ZC is offline   Reply With Quote
Old   June 5, 2014, 08:04
Ping
ping is on a distinguished road
you need to combine your inner block and the sphere into one part and then it will mesh only outside the sphere and the overset hole cutting will work - the message it quite logical
ping is offline   Reply With Quote
Old   June 5, 2014, 09:53
Cristina Zaragozano
It works !! Thanks a lot !!!!
Just one last question : the background mesh goes inside the sphere when i "hide" the sphere mesh in my mesh scene. Is it normal plz? (As you said though, the mesh of the overset doesn't go inside the sphere, as planned).
Old   September 7, 2019, 12:44
Default Same problem!!
Kev
SKBA is on a distinguished road
Can you please explain this solution, im new to this and i am having the same trouble
SKBA is offline   Reply With Quote
Old   September 9, 2019, 11:43
Ping
i suspect if you dont understand this then you need to go back to basics on what overset mesh is and how it works and maybe have a detailed read of the help and read some steve articles
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 14:21
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Help in setting up an overset mesh RKE STAR-CCM+ 1 February 21, 2014 22:35
OpenFOAM15 installables are incomplete problem with paraFoam tryingof OpenFOAM Bugs 17 December 7, 2008 05:41
