May 28, 2014, 16:37 |
Exporting the data from fluent to StarCCM+
Rep Power: 17 |
Does anyone know how to export the solution from fluent to StarCCM+? I have transferred the mesh, but is it possible to transfer the data as well?
Thanks, |
May 28, 2014, 17:17 |
Rep Power: 24 |
You need to export the data using a neutral format (Plot 3D or something). There is no direct path.
May 28, 2014, 18:42 |
Rep Power: 17 |
It seems to me that Star CCM+ only imports the (*.sim) files. Is there any menu in the software to import other types of file (3D plot, ...)? Thanks.
May 29, 2014, 10:33 |
Rep Power: 24 |
Yes, you need to go to file>import CAE model
June 2, 2014, 04:03 |
Ping
Rep Power: 20 |
i know nothing about fluent but if you can get the field data out in a csv file eg x, y, z, pressure, etc then it is easy to import this into ccm+ as a table then initialise the case via table and you can then post process so continue to solve etc
Exporting Data to Fluent Especially P_Mean | Alhasan | OpenFOAM Post-Processing | 0 | September 23, 2013 21:26 |
fluent udf problem: write specific data for every iteration in a file. | nnvoro | Fluent UDF and Scheme Programming | 1 | May 27, 2013 15:26 |
Data import in Fluent?! | Bart Horsten | FLUENT | 3 | February 22, 2010 13:05 |
Fluent Output Data Question | fossu15a | FLUENT | 3 | March 30, 2009 19:29 |
How to read tabulated data in Fluent | Siddhartha Pal | FLUENT | 0 | August 30, 2007 05:18 |
