May 21, 2014, 11:25 |
Artery and Tissue
#21 |
Fardin Khalili
Rep Power: 12 |
Sathwik,
Use only one fluid physics for both regions. Select Eulerian multiphase and choose two phases with different properties. And artery is porous region and tissue is fluid region. In Star-CCM the Darcy-Forchheimer equation is used by default. The inertial resistance coefficient is the Forchheimer term. To use the regular Darcy's law, simply set this coefficient to be zero. Use the interface as baffle |
May 21, 2014, 11:28 |
No vof
#22 |
Fardin Khalili
Rep Power: 12 |
Sathwik,
And totally forget about VOF. Change fluid physics models. |
May 21, 2014, 11:44 |
#23 |
Rep Power: 25 |
fardinkhalili,
I don't see how using EMP will allow them to move one phase across the interface but not the other. |
May 21, 2014, 11:48 |
Artery and tissue
#24 |
Fardin Khalili
Rep Power: 12 |
So you mean he can use two fluid physics, one for artery and one for tissue, then use porous region for artery that cause blood go through the baffle interface and get into the tissue. Right?
May 21, 2014, 11:57 |
#25 |
Rep Power: 25 |
Not quite. But this could be done a couple ways I suppose.
The way he's trying to do it, he has the tissue as a porous media which is also some fluid (some kind of plasma or something?). The blood needs to be able to move through the artery and into the tissue, but not the fluid in the tissue into the artery. Once in the tissue, the blood would mix with the second fluid. Now you could just say everything is blood and just treat the tissue as a porous media, then you would only need a single phase and this is really easy. But I think from what he's saying for some reason he needs the first option. Is that true Sathwik? |
May 21, 2014, 13:18 |
#26 |
Surigala
Rep Power: 12 |
The only fluid in both the regions is blood.so do u want me to set only one phase that too for artery??
May 21, 2014, 13:27 |
#27 |
Rep Power: 25 |
If there was only one phase to begin with, I'm not sure why you were trying to mess with multiphase models; perhaps some of the fault is on me for not questioning that. But yes, just use a single liquid and make your porous medium the second region, and this is very easy.
May 21, 2014, 13:30 |
#28 |
Surigala
Rep Power: 12 |
I want the artery to be permeable not porous.
May 21, 2014, 14:18 |
#29 |
Rep Power: 25 |
What's the difference?
May 21, 2014, 15:13 |
#30 |
Surigala
Rep Power: 12 |
Porosity:space in between the moleculesPermeability: ease of flow in that area
May 21, 2014, 15:18 |
#31 |
Rep Power: 25 |
In STAR-CCM+, there's a value on porous media called porosity which is analagous to how much area of a plate with holes is open, and then there are the porous coefficients, which modify how easy it is for flow to move. I would think you'd want to leave the porous coefficients to zero and just modify porosity then.
simulation of blood flow | Hoffenheim | Main CFD Forum | 0 | May 24, 2012 17:12 |
Differences and functions of Solidworks Simulation and Solidworks Flow Simulation? | alpharays | Main CFD Forum | 0 | April 19, 2012 04:13 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 13:19 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 22:31 |
Pulsatile blood flow in closed loops | Michael F. Wolf | Main CFD Forum | 3 | July 1, 1999 17:37 |
