Maximum Temperature greater than the boundary temperature
Old   May 19, 2014, 15:51
Question Maximum Temperature greater than the boundary temperature
Sathwik Singari
sathwik718 is on a distinguished road
Hello Everyone,
The figure below shows a flow pattern with width and height of each channel is 100um. The bottom surface is maintained at a temperature of 70C and the gas enters at 65C. The second figure is a side view of the first channel of the four channels. The maximum temperature reaches 74C. The inlet condition for pressure is 40 psi, but in the pressure scne the pressure reaches 45 psi. I dont understand why this happens. Any kind of help is appreciated.
Thank you
sathwik718 is offline   Reply With Quote
Old   May 19, 2014, 16:44
David VanBronkhorst
dvanb is on a distinguished road
What is the Mach number of this flow? If it is up above .35 the stagnation temperature could be 75C if you are specifying your inlet value as static temp.
dvanb is offline   Reply With Quote
Old   May 19, 2014, 17:33
Sathwik Singari
Thanks. The velocity in each channel is around 273 m/s. That give the mach number around 0.8. How do I calculate the stagnation temperature?
Old   May 19, 2014, 18:05
David VanBronkhorst
Tstag/Tstatic = 1+[(k-1)/2]*M^2
Pstag/pstatic = {[1+(k-1)/2]*M^2}^(k/(k-1))
k is the ratio of specific heats for your gas, 1.4 for air.
You can also find tables of stagnation properties listed by Mach number.
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
[openSmoke] libOpenSMOKE Tobi OpenFOAM Community Contributions 562 January 25, 2023 10:21
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 08:15
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
CFX fails to calculate a diffuser pipe flow shenying0710 CFX 7 March 26, 2013 05:13
