Finely dispersed particles in predetermined velocity field
Old   May 14, 2014, 04:52
Default Finely dispersed particles in predetermined velocity field
BrainDebugger is on a distinguished road
Hi
I am trying to simulate flow problem and use velocity field I get for problem
of moving finely dispersed particles in Star-CCM+.
I assume particles don't impact velocity field, so I don't need to recalculate it during particles movement modeling.
Velocity field modeling needs smaller time step and more calculation time for every iteration.
How can I calculate particles movement without recalculating velocity field?
BrainDebugger is offline   Reply With Quote
Old   May 14, 2014, 07:32
Ping
ping is on a distinguished road
you mention time step so you have the unsteady solver enabled so if you really do have unsteady flow then the particle motion will also vary with each time step
but if you only want to see the particle motion at a particular time you can leave the lagrangian solver frozen until you are ready then freeze the flow solver and run one iteration of the lagrangian solver since this is all that is required - change back to the steady solver for this
and with the flow solver frozen you can run any number of lagrangian runs with different settings to see the effect of particle mass or size etc
ping is offline   Reply With Quote
problems after decomposing for running alessio.nz OpenFOAM 7 March 5, 2021 05:49
Particle tracks for already calculated transient velocity field Tech Neo Fluent Multiphase 7 December 19, 2013 12:20
Solving transport equations with known velocity field Mojtaba.a OpenFOAM Running, Solving & CFD 6 August 6, 2012 08:43
Velocity field problem feizaghaee CFX 20 February 24, 2010 05:23
Pressure from velocity field Svante Hellzén Main CFD Forum 5 November 30, 1999 19:20
