Surface Values to Volume Mesh
Old   May 13, 2014, 03:07
Default Surface Values to Volume Mesh
Tim
Schwimmy is on a distinguished road
i'm working with starrccm+ and i have this following question: i have values on my surface mesh (field function) and i want to translate these to my volume mesh. So far so good. Each volume cell should get the value, which the nearest surface cell has.
I hope you all understand my short description
How do i get this fieldfuncion on my volume mesh?
Thank you
Tim
Schwimmy is offline   Reply With Quote
Old   May 13, 2014, 11:57
me3840 is on a distinguished road
This might be able to be done if the geometry is simple enough, but the procedure is complex.
But I feel that, from your description, I'm missing something. "Each volume cell should get the value which the nearest surface cell has". I don't feel this is a good enough description to get a unique and smooth distribution of your function through the domain.
me3840 is offline   Reply With Quote
field function, mesh, surface, volume
[ICEM] Extracting Surface from Volume mesh Joh ANSYS Meshing & Geometry 1 April 20, 2016 18:10
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
[Commercial meshers] converting a surface mesh to volume mesh monish OpenFOAM Meshing & Mesh Conversion 0 June 25, 2012 07:23
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
