Insulated pipe heat transfer
Old   May 12, 2014, 03:46
Default Insulated pipe heat transfer
Andrew Gunderson
gundy is on a distinguished road
In simulating heat transfer through a pipe with convection boundary conditions on the inside and out, I used the field function
($$Position(@CoordinateSystem("Laboratory.Cylindri cal"))[0]<0.3)?55:0.04
to define a thermal conductivity of 55 W/m-K when the radius is <0.3 (for the pipe) and 0.04 W/m-K for radius>0.3 (for the insulation). However, I get the error message
"Field function "Variable Conductivity" cannot be evaluated on region Pipe solid"
when assigning this field function to the Thermal Conductivity material property. Any suggestions?
gundy is offline   Reply With Quote
Old   May 12, 2014, 20:58
me3840 is on a distinguished road
Why do you need a field function for this? Just put a different BC on the inside and outside of the pipe.
me3840 is offline   Reply With Quote
Old   May 12, 2014, 21:33
Andrew Gunderson
Thanks for the reply. Perhaps I wasn't clear; I simulated the pipe and insulation as one solid cylinder with a hole in the middle (there are, of course, other ways to do this). For the sake of experimenting with field functions, I intended on using my function to define the conductivity of the outside portion (.3<r<.4) of the pipe as .04 (effectively creating the insulation) and the inside (.2<r<.3) as 55 (the pipe).
I've used field functions before to set initial values for temperature and such, I just can't figure out why it won't work for material properties.
Old   May 12, 2014, 22:41
I don't think this is a very good idea. You're leaving material properties down to an interpolation algorithm.
I would recommend you mesh the two solids and interface them instead.
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff swahono OpenFOAM Running, Solving & CFD 10 October 15, 2018 06:43
Fluent Tutorial on Heat transfer Far FLUENT 15 July 29, 2017 16:31
Porous domain:Interfacial area density and heat transfer coefficient l.te CFX 2 May 18, 2014 00:45
heat transfer along a pipe lysander FLUENT 0 July 28, 2012 00:39
heat transfer in an nonadiabatic pipe with reaction ps_sameer Main CFD Forum 1 July 12, 2010 21:20
