time dependant velocity inlet for multiphase flow
Like Tree1Likes
Old   May 16, 2014, 06:22
vincent
vince60270 is on a distinguished road
hello ping,
i setted a time step of 0.01 with 9 inner iterations over 10s after several tests and the results are impressive they are quasi similar with the ones i got when i was running simulations Speed after Speed. thank you very much for all your help. :-)
vince60270 is offline   Reply With Quote
Old   August 8, 2014, 10:57
uuu
uuu is on a distinguished road
The problem seems to be solved BUT for upcoming readers:
Maybe lowering the corresponding under-relaxation-factors could lead to a solution too?!
at least it SEEMS to work for my problem which is, i think, kind of similar..
this would be much easier..
uuu is offline   Reply With Quote
Old   February 22, 2023, 16:34
Thumbs up хорошо
  #23
Peresvet
Peresvet is on a distinguished road
Originally Posted by ping View Post
the normal velocity field will be zero since the water is now not moving ie it is actually more like a real hull moving in stationary water
so as I said in an earlier post you need to instead use the field called relative velocity
(DFBI) overset also works.
Peresvet is offline   Reply With Quote
help needed, problem set-up, troubleshooting
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 23:40
Steady pipe flow mean velocity higher than inlet velocity anita OpenFOAM Running, Solving & CFD 7 September 25, 2012 06:35
How to find a good time scale strategy? StefanG CFX 19 June 8, 2012 09:41
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 06:24
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 14:11
