April 24, 2014, 06:00 |
heating of part of the pipeline
Hi all
I have a problem with heating part of pipeline. Ihave a 9 m pipeline and i need to heat just 0.5 m from beginning. So firstly when part of pipeline is heated the temperature and viscosity of oil in pipe should change. When i heat, in my case not only part but all pipeline is heated. Could u help me with this Thank in advance |
April 24, 2014, 12:20 |
Rep Power: 24 |
You need to separate the pipe at the 0.5m mark to ensure conduction does not occur to the rest of the pipe.
April 25, 2014, 06:31 |
pipeline heating
Thanks a lot. So for this should I greate a new region or not? I tried heat only inlet region, but I have the following mistake
A floating point exeption has occured. ...... |
April 25, 2014, 06:34 |
pipeline heating
And how I can do the separation at 0.5m?
many thanks |
April 25, 2014, 06:40 |
pipeline heating
I am so so sorry. Could you be more presicely, how I can separate the region?
any help will be appraciated Last edited by Aika; April 25, 2014 at 09:15. |
April 25, 2014, 09:39 |
Rep Power: 24 |
Create just a box that encompasses the part of the pipe you want to split, and then do a boolean subtract with the part.
Though if you're getting a floating point exception, there's probably something wrong with your setup. |
April 29, 2014, 09:40 |
DaveyBaby
Rep Power: 13 |
Hi!
For a metal pipe, there should be a significant amount of heat transfer along the solid that you need to take into account.
Have a look at: Tutorial Guide > Heat Transfer and Radiation > Conjugate Heat Transfer: Heated Fin This shows you some of the concepts that you will need. Field functions are very useful for defining boundary conditions. Using Tools > Using Field Functions > Field Function Programming Reference will give you the syntax you need to define something of the type: if(distance<x2 and distance>x1) "heat" else "no heat". |
May 5, 2014, 09:05 |
pipeline heating
Many thanks
I will try |
May 5, 2014, 09:09 |
#9 |
Thx a lot for your help. I've created 2 bodies and used boolean, but my 2 regions are calculated differently. Could u help? |
May 5, 2014, 09:19 |
#10 |
DaveyBaby
Rep Power: 13 |
Have a look at Defining The Simulation Topology > Working with Interfaces You need to create an interface between the 2 regions, even if they are next to each other in the CAD model. |
May 7, 2014, 07:09 |
#11 |
Ping
Rep Power: 20 |
if you are only want to input different heat values or temperatures locally then you don't need different regions but instead just a different boundary which can be done by imprinting in 3d-cad to separate the outside wall of the pipe into two surfaces
May 9, 2014, 07:02 |
pipeline heating
#12 |
Hi ping
Thx a lot. I am a beginner In my case the temperature of oil doesn't change, i din't know why. Initially I set up 500 C degree and oil temp should change between 500-300C degree. But initially in 1-3 steps oil temp becomes 300C. And about the viscosity changing I couldn't have a result I tried firstly with one region and set up fir inlet heat flux, so I have no a really result. If you have time could you review my model, many thx |
May 11, 2014, 09:16 |
cyclone simulation
#13 |
Hi guys
Please help me. I simulate the water flow in cyclone (for now just water without sludge) and my model is working. But my initially setting parameters (constants) have changed totally. Thx in advance |
July 11, 2014, 01:49 |
pipline heating
#14 |
Hi all
Could you help me with fiel function definition? I should create a field function for oil viscosity, because it changes due to temperature difference How I can write a definition (scalar field) I wrote $$Position[0] and after my simulation shows me an error many thx |
July 11, 2014, 07:04 |
Finding syntax for field function programming
#15 |
DaveyBaby
Rep Power: 13 |
Hi! Star's help files are hard to follow, it's easy to end up going round in circles.
Type "Field function programming reference" for the header menu to all the syntax definitions you may need. This sounds simple, but it's hard to find in the help section by searching! |
July 21, 2014, 02:39 |
pipline heating
#16 |
thanks a lot |
July 22, 2014, 06:09 |
#17 |
Gajendra Gulgulia
Rep Power: 13 |
Hello Aika
You can try seperating the boundary instead of creating entire region. Do the boolean operation as mentioned above and create a seperate boundary in the same region. Enable thermal conductivity/wall heat flux option under the boundary physics condition. In case you want to go with seperate region, make sure that you are creating interface b/w solid-solid and solid fluid boundary. Hope this was helpful |
July 22, 2014, 06:12 |
pipline heating
#18 |
Thank you so much
Applying Loads to Part of a Surface/spliting a part in ANSYS | 123catty456 | Main CFD Forum | 1 | July 29, 2013 12:52 |
replacing of shock tube high pressure part with a boundary condition for low pressure | immortality | Main CFD Forum | 0 | May 2, 2013 13:30 |
what boundary condition is proper for simulation of shock-tube low pressure part? | immortality | OpenFOAM Running, Solving & CFD | 0 | May 2, 2013 13:22 |
Modelled Part of Reynoldstresses in Channelflow | LeFrog | OpenFOAM Running, Solving & CFD | 0 | November 16, 2012 09:01 |
Integer part in StarCD macro | crevoise | Siemens | 2 | July 2, 2012 03:06 |
