Problem setting up Condensation
Old   April 24, 2014, 05:37
Default Problem setting up Condensation
cwl
Chaotic Water
cwl is on a distinguished road
Hi everyone
I am trying to model condensation of vapor on air streams. Case description: 2D axisymmetric cylinder with air inlet at one end (10 C; average velocity 0.3 m/s, set as MassFlow boundary condition), outlet at another end (Pressure outlet boundary condition) and an additional inlet for steam on the wall (50 C; average velocity 3 m/s).
Models: // not all, but the important ones
Implicit Unsteady
VOF: multi-component gas (vapor + air), multi-component liquid (water)
Antoine Equation for Saturation Pressure of Water
Condensation set at Phase Interaction (Primar Phase - water)
Surface Tension
Time-Step 0.01 s // whatever
Without Condensation model set at Phase Interaction everything is fine (see img.); but when this model is turned on - Temperature drops to 0 K at vapor inlet (see img.) and no condensation occurs at all (Volume Fraction of Water is strictly zero everywhere).
I have no idea, why this happens - neither physical explanations, nor computational i've got.
If anyone has any idea or a simple working case of condensation (no film) - i would appreciate yor help greatly.
cwl is offline   Reply With Quote
Old   April 29, 2014, 04:10
Post
Miki12 is on a distinguished road
Hi cwl,
I'm doing the same kind of simulation, do you try to remove the surface tension model? Do you try with evaporation? I have the same problem as you, I have no creation of water.
I have asked the people from CD-Adapco, they told me to pue at the initial, a very little amount of water.
Do you try with another approach ( fluid film, lagrangian, eulerian-eulerian) ?
Thank you,
Miki,
Miki12 is offline   Reply With Quote
Old   September 1, 2017, 07:35
mike
raskolnikov is on a distinguished road
Do you have any solutions for this problem? I see also no phase change for a same flow simulation.
raskolnikov is offline   Reply With Quote
Problem setting C_MU_T with DEFINE_ADJUST Andy FLUENT 3 June 22, 2018 03:53
Problem? with Installation of OpenFOAM 2.1.0 on to Ubuntu 10.4.4 VirtualBox Stubby OpenFOAM Installation 8 March 5, 2012 16:12
Problem setting regions danigorgeos STAR-CCM+ 2 March 1, 2012 07:15
UDF for condensation problem Mahesh FLUENT 8 March 31, 2011 13:07
Chem. Reaction and Ignition Setting in ICE Problem Tulus Siemens 0 March 28, 2005 01:02
