Particle tracking----HOW???
Old   April 23, 2014, 23:16
Smile Particle tracking----HOW???
mohammad
mohammad is on a distinguished road
Hi
I have a problem about how to check the particle tracking in postprocessing...
I have already done my steady state simulation of flow and now I want to know how to see the trajectory of a single particle...
I would be appreciative if sb can help me.
Tnx
mohammad is offline   Reply With Quote
Old   April 24, 2014, 06:45
Default track file
azt
allan thomson
azt is on a distinguished road
Hi
You probably need to write out a track file. Do a search in the help with the words 'track file'
azt
azt is offline   Reply With Quote
Old   April 24, 2014, 12:35
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
The final iteration should cause a *.trk file to be written. You can then load this under "Tools > Track" in the simulation tree. This will make various track variables available. There is also a description somewhere in the docs about plotting this via an animation etc. I don't however find that so terribly useful.
An alternative is to restart your simulation as a transient calculation, with all of the solvers set to "frozen" except the lagrangian and let a few iterations run. This way you can visualize the lagrangian phase directly. You should however remember to turn off two-way coupling to avoid polluting your results.
/mark
olesen is offline   Reply With Quote
Old   April 24, 2014, 12:42
mohammad
/mark
Hi Olesen;
Thank you for your help.
I did the one iteration with Lagrangian phase. and I saw the number of points which means that the method is ok. I also saw some of the points (tracking points) in a scene. However, do you know how to create a single streamline which passes through all of those points?
I highly appreciate your favor in advanced.
particle tracking
dispersion model with lagragian particle tracking model for incompressible flows eelcovv OpenFOAM Running, Solving & CFD 54 April 10, 2018 10:36
Blood Damage Modelling via Particle Tracking in a Centrifugal Heart Pump scatman CFX 7 January 8, 2018 01:59
Ubuntu 12.10 + openfoam2.2.0 ==> paraview error message peteryuan OpenFOAM Installation 6 August 18, 2013 19:00
[OpenFOAM] ParaView ErrOr soheil nazmdeh ParaView 1 August 17, 2013 08:40
injection problem Mark New FLUENT 0 August 4, 2013 02:30
