Star ccm 9.02 - unsteady flux dissipation correction
Old   April 18, 2014, 09:06
Default Star ccm 9.02 - unsteady flux dissipation correction
Phoevos
fivos is on a distinguished road
Hi to everyone,
Has anyone any explanation what the unsteady flux dissipation correction does exactly at transient compressible simulations? This is a new feature in v9.02, under the segregated flow (continua-> physics -> models -> segregated flow). In the documentation there are not much info, apart from:
Enable/disable mass flux dissipation corrections for unsteady simulations, modifying the coefficients in Eqn. (208), based on CFL
and
The limiting acoustic CFL, applied for unsteady simulations, to scale the mass flux dissipation. The default value is 1.0. Larger values damp more spurious oscillations, but at the expense of accuracy.
I have simulated two highly compressible case with a custom EOS (in all cases the time step is chosen in such a way that the acoustic courant is 0.5):
- A shock tube: without the unsteady flux dissipation correction the solution matches well with the theory; the characteristic regions are predicted correctly (L, R, L*, R*) and the wave speeds as well, while the solution is sharp at the shock and smooth at the rarefaction wave. With the unsteady flux dissipation correction (CFL = 1) the main characteristics of the solution are the same (wave speeds and region characteristics), but there are additional wiggles and oscillations introduced near both the shock wave and the rarefaction wave! This seems to contradict what is mentioned in the documentation..
- A foil: without the unsteady flux dissipation correction I get unphysical high values for pressure and also there is a checker-board pattern in the pressure field (!). With the unsteady flux dissipation correction (CFL = 1), I get a much clearer pressure field.
From the two cases there seems to be a contradicting behavior of this correction. Does anyone have any additional information?
Thanks in advance.
Regards
fivos is offline   Reply With Quote
Old   April 18, 2014, 14:09
Philhellene Ithaca
yannaos is on a distinguished road
You can find the detailed formulation for the Unsteady Dissipation Corrections within STAR-CCM+ help (v902) under:
User Guide > Modelling Physics > Modelling Flow and Energy > Fluid Flow Formulation > Segregated Flow Formulation > Continuity Equation in Discrete Form
and there, please look for the Unsteady Dissipation Corrections section.
yannaos is offline   Reply With Quote
Old   April 18, 2014, 16:50
Phoevos
Thanks yannaos for your reply. I have seen the exact formulation for the unsteady dissipation correction in the density correction, but, since it is entirely focused on formulas, I cannot understand its exact meaning and, most importantly, its effect (apart from that it damps oscillations, even though the shock tube test case showed the opposite..).
To be honest with you, its the first time I see this correction and I am not sure if I apply it correctly. I am going to search for it more thoroughly, but do you (or anyone else) know any relevant publications showing the idea of this corrector and maybe test cases?
Thanks in advance.
Regards.
Old   April 27, 2014, 19:31
Philhellene Ithaca
Within the STAR-CCM+ guide, under Release Notes>..> Enhancements, you can find also the following bit of information about the Unsteady flux dissipation corrections:
"Correction based on the local acoustic CFL number to reduce spurious sound wave reflections for unsteady acoustics simulations".
Strictly speaking, your case 1/ does not contradict this tool, because as you pointed out, you had a well behaving solution. So, why using corrections tools?
Your second one, is much more interesting: If confirmed, it would mean that this tool could provide a solution to checker-board problems.
Old   April 28, 2014, 10:37
Phoevos
Ok Yannaos, thanks for your time and responses. If I find anything new, I will post it here..
STAR CCM & WIN 8 pro hyderkhan74 STAR-CCM+ 3 March 5, 2014 05:56
Unsteady and Flux UDFs for UDSs tom FLUENT 0 February 13, 2009 11:27
error in star ccm+ unsteady problem Yue Siemens 1 April 2, 2007 12:15
mass flux correction at outflow boundaries Subhra Datta Main CFD Forum 2 November 24, 2003 14:11
total mass flux correction for compressible fluid? Francesco Di Maio Main CFD Forum 0 August 21, 2000 05:23
