help: an error occurred in the process of simulation |
April 18, 2014, 03:25 |
Rep Power: 12 |
An error occurred. The simulation stops. i do not konw how to solve it.
April 18, 2014, 15:55 |
Rep Power: 24 |
This is a segmentation fault and likely a bug. Report this to your support engineer.
What were you trying to do? |
April 20, 2014, 02:36 |
Rep Power: 12 |
I just try to compute a drag of the structure.
April 20, 2014, 02:47 |
Rep Power: 12 |
I remeshed, run the simulation again. After a while, simulation stops.
April 21, 2014, 12:58 |
Rep Power: 24 |
So at some iteration N it just stops and gives this message? Something has to have changed.
April 24, 2014, 10:16 |
Rep Power: 12 |
yes, the simulation just stops after some iteration N. in low fr number, i change the time step, turn time step smaller, it works. but in high fr number, i also change the time step, it does not work.
April 24, 2014, 12:22 |
Rep Power: 24 |
Are you running this with a custom Java macro?
April 24, 2014, 21:34 |
Rep Power: 12 |
No,I do not run this with a custom java macro.are there some physical variables such as p,v,k,w divergency?Because of divergency the simulation stops after some iterations.
error memory |
Simulation time vs. Simulation Cell Count | chrisoturner | Main CFD Forum | 7 | September 8, 2012 17:46 |
Linux Batch - Star-CCM+ .. running Sims in batchmode | eRzBeNgEl | STAR-CCM+ | 3 | August 29, 2011 04:43 |
FSI TWO-WAY SIMULATION | Smagmon | CFX | 1 | March 6, 2009 13:24 |
Help for simulation of De-sublimation process | sohail | FLUENT | 0 | March 27, 2008 01:51 |
Casting Process Simulation | Anil Shenoy | Main CFD Forum | 1 | February 22, 1999 11:56 |
