Calculating surface area in Axisymmetric simulation |
April 16, 2014, 06:49 |
Chaotic Water
Rep Power: 18 |
Hi
I have a simple axisymmetric simulation: cylinder with ends as inlet and outlet - and an additional inlet that is a separated part of side cylinder surface, just a winded rectangle it would be in 3D. No problems converting to 2D, setting Axis boundary condition. Cylinder has R = 0.25 m and additional inlet has length of l = 0.05 m; so Inlet Area should be S1=Pi*R^2 and additional inlet area should be S2=2*Pi*R*l; their ratio S1/S2 = 2.5 I'm still confused on how Area is computed in Axisymmetric case: Report (no matter - Sum of Area on surface or Surface Integral of Field Function with Definition set to "1") returns S1 = 3.125E-2 m^2 and S2 = 1.25E-2 m^2. These values have the same ratio of 2.5. If i get it right - surface is calculated not for angle of 2*Pi, but for angle of 1 rad. Has anyone got any ideas of whether i understand thing right and .. why the hell is it 1 rad - not 2*Pi? |
April 16, 2014, 14:09 |
Philhellene Ithaca
Rep Power: 12 |
For asysymetrical calculations, effectively, STAR-CCM+ assumes the non-resolved dimension to be 1 rad. (For 2D cases, 1 m).
I suppose they preferred to strictly use 1 SI (m) or 1 SI derived (rad) unit. |
February 16, 2022, 08:51 |
#3 | |
sina
Rep Power: 4 |
I want to compute the area in 2D axisymmetric that fluent use for computational , Does it obtain from pi*r^2? Best Regards, |
Surface Area | jxs832 | Tecplot | 5 | February 16, 2016 13:18 |
Non overlap area fractions | saisanthoshm88 | CFX | 11 | September 17, 2015 18:42 |
free surface simulation with parallel caculation? | rabbitmelon | CFX | 1 | July 27, 2013 07:13 |
Surface from area between bodies | sualocin | CFX | 0 | January 3, 2011 18:05 |
Can Flow-3D plot the free surface area in Iso-surface or colour variable? | therockyy | FLOW-3D | 1 | June 20, 2010 19:36 |
