acceleration and deceleration of a moving body
Old   April 9, 2014, 21:34
Default acceleration and deceleration of a moving body
JohnAB is on a distinguished road
I am using the overset method to simulate a very simple translation movement:
- my little cube (moving body, "overset" Region) has a translation motion along x.
The simulation works great for the steady state but my problem is that my speed is going straight from 0 to steady state and what I want is the cube to accelerate slowly from 0 to steady state, and then, after a given number of iterations, decelerate to 0.
How can I do that ?
In Regions > Overset, I can only enter the speed in the "Initial Conditions" tab. There I put [0;0;0] since I want to start from 0.
then, in Regions > Overset > Physics Values > Motion specification, I put User Defined Vertex. I figured it is the only one that could work, since translation can only do steady state (I have tried it and created a new translation in the Motions folder, but no way to put an acceleration/field function there...).
After that, I'm stuck, I tried ever User Defined Vertex Option, with no luck...
It would be nice if I could move forward and solve this.
Thanks!
JohnAB is offline   Reply With Quote
Old   April 9, 2014, 23:11
me3840 is on a distinguished road
You can put user-defined functions in motions, just type them in. Either create three scalar field functions (or fewer if some are zero) for your three components of velocity or just create a vector field function that has all three built in. Then just type in [$x,$y,$z] for the former or $$vectorFieldFunctionName for the latter.
me3840 is offline   Reply With Quote
Old   April 11, 2014, 12:34
I got it to work, thank you!
one more thing, how do I add the deceleration in the same field function ?
I understand it is going to look very similar to acceleration, but what is the syntax that links the two expressions ? I tried a comma, going to next line, a semi-colon, etc.. and it did not work...
thanks for all your help!
Old   April 11, 2014, 15:38
I'm not entirely sure if this is what you're trying to achieve, but you can nest if statements. For example, consider this function that ramps up and down a scalar value of 10 for the first second and 5th second, respectively.
($Time<1.0)?10*$Time/1.0($Time>4.0)?10*(1/($Time/5.0)):10.0)
Old   April 11, 2014, 16:24
I did not know how to nest the statements so this is exactly what I needed! I am going to try it, thanks!
Old   August 4, 2021, 00:20
Anonymous
mna23 is on a distinguished road
Hello Mr. John. I see that you have succeed to define the acceleration for flat wave accelleration from 0 m/s to x m/s. Can i kneow about the user field function that you have defined? i have the same problem too to have speed up for my ship simulation. It great if you reply this massege. Thanks. Regards.
mna23 is offline   Reply With Quote
