How to define a motion to simulate the oscillating airfoil |
April 8, 2014, 17:47 |
Tong Zhou
Rep Power: 15 |
I want to simulate the oscillating airfoil by using dynamic mesh in time domain. How can I define the motion?
April 8, 2014, 22:27 |
Rep Power: 25 |
Create a rotating region inside your exterior region. Then create a motion for the rotating region under tools>motion. Define a function (probably some kind of sine wave) for that motion.
April 8, 2014, 22:51 |
Tong Zhou
Rep Power: 15 |
Thank you for reply. How to define a sine wave motion in star com? I can not find the option of UFD. There are only settings for rotation axis, anglar velocity...etc
April 9, 2014, 03:36 |
william
Rep Power: 16 |
may be you can create a transition motion,and create a function to control the motion.
April 9, 2014, 12:16 |
Rep Power: 25 |
Just type in a function in the field for the rotation rate.
April 9, 2014, 13:22 |
Tong Zhou
Rep Power: 15 |
Thank you so much. Can you give me a sample of function, such as a motion of frequency 10Hz and amplitude -5 to 5 degrees. Or can I find some useful information from the UserGuide? I can not find it so far...
April 9, 2014, 13:34 |
Rep Power: 25 |
Look for the section using tools> using field functions
April 9, 2014, 16:22 |
Tong Zhou
Rep Power: 15 |
I have defined a new field function which named "Motion", the expression is 0.5*sin(2*3.14*$Time). Then I type "$Motion" in rotation rate and got the warning below:
"Error: Unable to compile field function: Motion (Motion) Cannot resolve function ${time}: "time" not defined." what does that mean? |
April 9, 2014, 18:14 |
#9 |
Rep Power: 25 |
This error is likely because your physics continuum is not set to be unsteady. The function $Time does not exist for steady cases.
Note your field function must return radians/s. Originally you wanted it to turn through some degree sweep - ensure (a) that you are using radians and (b) you differentiate your function so it is a rotation rate. |
April 9, 2014, 18:48 |
#10 | |
Tong Zhou
Rep Power: 15 |
i chose the implicit unsteady solver. The new field function including $Time can be created normally. The error showed up when I defined the rotation rate.
April 9, 2014, 20:02 |
#11 |
Rep Power: 25 |
Be sure you are using a capital T as well. It worked for me when I tried it.
April 9, 2014, 22:34 |
#12 |
Tong Zhou
Rep Power: 15 |
April 9, 2014, 22:49 |
#13 |
Rep Power: 25 |
No, just the $fieldFunctionName.
Go through your field function list and ensure that Time is one of them. If it is not one of your physics continua is set incorrectly. |
April 9, 2014, 23:02 |
#14 |
Rep Power: 12 |
HI,how should i creat the rotational region?
April 9, 2014, 23:55 |
#15 |
Rep Power: 25 |
April 10, 2014, 14:56 |
#16 |
Tong Zhou
Rep Power: 15 |
August 20, 2014, 17:55 |
#17 |
Justin
Rep Power: 12 |
Shelley,
Is there a way to make an animation of an airfoil oscillating with the varying velocity distribution shown? |
How to define oscillation of an airfoil? | Farid | CFX | 5 | April 27, 2008 21:07 |
How can i simulate a valve motion ???????? | popi | CFX | 6 | September 19, 2006 11:54 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 13:24 |
BC for oscillating airfoil | ganesh | Main CFD Forum | 4 | July 7, 2005 13:29 |
Can I define grids motion as a time functions | Darcy | CFX | 4 | March 29, 2001 22:14 |
