Rectangular pulse as field function
Old   April 3, 2014, 08:30
Default Rectangular pulse as field function
Jul
Jul1731 is on a distinguished road
Hi guys,
I am trying to create a field function (first time I am doing that on Star) to make a velocity inlet depending of the time.
I want to create a rectangular pulse so I am using a sinusoidal function, and when this function is positive the velocity will be like 80m/s and when it is negative, the velity will be zero.
So here is the field function I have created:
(sin(352*$Time)>=0) ? $$Velocity=80 : (sin(352*$Time)<0) ? $$Velocity=0
Unfortunately, this function doest not compile. I can't find what I have did wrong ... do you have any ideas where I have done a mistake ?
Thank you
Jul1731 is offline   Reply With Quote
Old   April 3, 2014, 09:09
Robert
RobertB is on a distinguished road
Velocity is a vector, you will need something like $$Velocity[1] (Y velocity) or use $VelocityMagnitude if you want a scalar.
RobertB is offline   Reply With Quote
Old   April 4, 2014, 09:32
Jul
Thank you for your answer.
My code is now compiling but still not working.
So I tried to set a field funtion very simple as:
$VelocityMagnitude==80
And the velocity keeps to zero ...
Do you have any idea where I am doing wrong ?
Old   April 4, 2014, 12:54
Jul
I have found the solution !!
Thank you for your help !
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
foamToTecplot360 thomasduerr OpenFOAM Post-Processing 121 June 11, 2021 11:05
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 08:15
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Droplet Evaporation Christian Main CFD Forum 2 February 27, 2007 07:27
