March 28, 2014, 10:58 |
Verification: Couette Flow
Andrew L. Bloxom
Rep Power: 16 |
Hi All,
I'm working on a write-up about code verification and have been performing a comparison with the Couette flow analytical solution to look at the spatial observed order of accuracy. I'm seeing some interesting results where the 2nd order segregated flow solver is converging with at an observed 1st order rate. I have tried different set-ups with steady flow, primarily: a) 2D with period interface BC's on the ends and upper wall with tang. vel. b) 2D with vel. inlet(specified exact inlet profile)/press. outlet BC's on the ends and " " c) 3D cube with vel. inlet(specified exact inlet profile)/press. outlet BC's, SYM planes, and " " Also, I ran unsteady and reached the same conclusions. Has anyone else seen this behavior in your studies? |
couette flow, verification |
Couette Flow in Matlab using Pressure Correction Method | mulchah | Main CFD Forum | 4 | February 25, 2014 06:41 |
2D Couette/ Poisuelle Flow | CFD Guy | FLUENT | 1 | April 30, 2011 10:48 |
Simulation on Couette flow | cheng | Main CFD Forum | 4 | February 11, 2009 09:29 |
Couette Flow | Tex | FLUENT | 1 | November 30, 2005 05:47 |
Couette Flow | Vijay Patel | Main CFD Forum | 2 | April 18, 2002 12:29 |
