Aerofoil Modelling - Laminar approximation, transition and turbulence modelling.
Old   January 18, 2014, 06:49
Default Aerofoil Modelling - Laminar approximation, transition and turbulence modelling.
Craig
Asatorae is on a distinguished road
Hello all,
I was wondering if I could get some advice.
I am modelling an aerofoil at various angles of attack and velocities.
I ran some validation cases in 2D and 3D first using a Steady, Laminar model and then using the Implicit Unsteady Spalart-Almaras turbulence model.
Both systems showed reasonable agreement of both lift and drag coefficient for angles of attack up to the plateau at stall condition.
I have a few questions though (the aerofoil under consideration has roughly similar geometry to NACA 4412 or Clark Y):
>> When is it appropriate to use a laminar approximation - could I perhaps assume that the separation of flow and development of a turbulent boundary is negligible for low (0-5 degrees) angles of attack?
>> Am I right in saying that by using an Implicit Unsteady system with Spalart-Almaras turbulence, I am saying that the flow IS turbulent, and that the turbulence model in itself has no way of predicting the transition from laminar to turbulence.
>> Would it be better, perhaps, to use a K-Omega model with the Gamma-Re-Theta transition model such that the CFD may predict transition to a turbulent boundary layer and the position of flow separation ... I tried this, the results seem okay but I don't get a 'trail' of low velocity flow behind the aerofoil as I do in the laminar or Spalart-Almaras case.
Thank you very much!
Asatorae
Asatorae is offline   Reply With Quote
Old   January 20, 2014, 06:25
siara817's Avatar
siamak rahimi ardkapan
siara817 is on a distinguished road
Have you tried to use some transition models? Check out the tutorial.
Good luck
Siamak
siara817 is offline   Reply With Quote
region of transition laminar flow to turbulence flow farzadpourfattah FLUENT 2 August 22, 2013 07:11
Code release: Flow Transition and Turbulence Chaoqun Liu Main CFD Forum 0 September 26, 2008 18:15
Transition from laminar to turbulence Devang CFX 2 June 24, 2008 03:27
modelling transition with v2f turbulence model pablo FLUENT 0 August 7, 2006 16:44
turbulence modeling questions llowen Main CFD Forum 3 September 11, 1998 05:24
