Radiation - Emissivity
Old   December 18, 2013, 12:09
Question Radiation - Emissivity
crevoise is on a distinguished road
Hello
I wish to simulate the heat losses and the radiation of an exhaust pipe.
For now, I am using the 'convection' option for the heat losses. The radiation is thus mobilized with the surface emissivity.
I wish to try the 'environment' option for the heat losses.
Thus, for the radiation, in addition to the 'surface emissivity', appears the 'external emissivitiy'.
What is the difference between the surface and the external emissivities?
Does this external emissivity is relevant in such a case?
Thank you for your help and explanations
crevoise is offline   Reply With Quote
Old   December 19, 2013, 09:54
siara817's Avatar
siamak rahimi ardkapan
siara817 is on a distinguished road
External emissivities can be important if the heat exchange between the outer walls of your domain and surrounding environment is significant. I think in your case that you are simulating an exhaust pipe, you can not simulate the whole world around the exhaust pipe. Instead you can use this environment model and external emissivity to consider the heat radiating to environment.
Good luck
Siamak
siara817 is offline   Reply With Quote
Old   December 19, 2013, 10:13
Hello Siamak
Thank you for your answer.
There is indeed huge different in the results computations, when activating the 'external radiation'.
Compared to StarCD, I did not find any 'external radiation' option, but only the 'surfacic radiation' one.
Do you know if there is a way to implement such 'external radiation' in StarCD?
Thanks again for your help
Old   December 20, 2013, 12:42
Zeppo's Avatar
Sergei
Zeppo will become famous soon enough
Take a look at the documentation supplied with the software. It shows how this boundary condition can be used in a particular case with car windows.
Zeppo is offline   Reply With Quote
external emissivity, heat losses, radiation, surface emissivity
wall emissivity for radiation problem: emitter is also receiving when it shouldn't Young FLUENT 14 January 7, 2016 07:08
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Modeling both radiation and convection on surfaces - Ansys Transient Thermal R13 s.mishra ANSYS 0 March 31, 2012 05:12
Multiphase radiation in CFX Luk_Fiz CFX 5 March 17, 2009 04:51
Radiation and interfaces Frank CFX 2 June 22, 2005 12:26
