October 30, 2013, 02:25 |
Supersonic static pressure
AHMAD
Rep Power: 13 |
Hi, I'm quite new with Star CCM+.
I am trying to simulate a flow inside an axial turbine. I am using steady state couple flow. The boundary conditions are from a real model gas turbine. I set the inlet condition to be a stagnation inlet. The problem is that is asks for a supersonic static pressure? Does anyone know how can I can get this value. I have been doing the same simulation using Ansys CFX. But the mach number at the inlet shows no sign of sonic flow. so does it mean that the I should leave it as 0? or should i use the mach number relation to get the static pressure? If I use the mach number relation, the static pressure will almost equal the total pressure since the mach number at the inlet is 0.12. |
error: uninitialized local variable 't' used | MASOUD | Fluent UDF and Scheme Programming | 5 | October 17, 2016 05:24 |
Maintaining Static Pressure at Fluid Flow Inlet | cdevalve | FLUENT | 3 | January 14, 2012 01:11 |
enum | MASOUD | Fluent UDF and Scheme Programming | 0 | June 5, 2010 01:49 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 16:00 |
