October 28, 2013, 11:01 |
How to improve bad Volume Mesh in Edges
Rep Power: 13 |
The following picture shows my current Mesh condition in my volume mesh. Do you have an idea, how to improve the edge quality of the prism layer? Thanks in advance Renee |
November 4, 2013, 00:56 |
AHMAD
Rep Power: 12 |
maybe you should try to reduce the prism layer thickness.
Have u tried calculating the estimated y+ value? |
November 6, 2013, 08:53 |
Rep Power: 13 |
The y+ value is mostly 1
January 3, 2014, 08:29 |
siamak rahimi ardkapan
Rep Power: 18 |
Is it essential that you use prism layers? If it is not do not use prim layers and instead work on your mesh size and growth rate.
Good luck Siamak |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 06:41 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 07:47 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
ICEM clustering of mesh points and multiple edges | webhaw | CFX | 4 | July 25, 2007 16:29 |
