User Code and Surface Heat Flux Assistance
Old   August 2, 2013, 12:44
Default User Code and Surface Heat Flux Assistance
Dylan
Dyls is on a distinguished road
Hi, I have been trying to run a model to validate surface temperatures on buildings and street in an outdoor model. The model is running a steady RANS standard k-epsilon turbulence model with solar loads turned on. In addition, I am using the Boussinesq approximation to account for buoyancy. Eventually, the model would be running the transient solar calculator for a full day.
The problem is that my surface temperatures seem to be hotter than I would expect them to be realistic. As I refine the mesh near surfaces, this temperature becomes "slightly" more reasonable (at the cost of computation time, of course).
My solution to this problem would be to implement a user code that would use a correlation to take heat away from the cells at the surface and move it to adjacent air cells, effectively parametrizing the surfaces.
Is there any problem with doing this? And is there any user code "guide" that could help me learn exactly how to start going about this. I have been reading the user manual in Star CCM+, but any additional help would be greatly appreciated. I really just need some assistance on getting started.
Thank you so much for your time and help!
Dylan
Dyls is offline   Reply With Quote
Code to obtain correct heat transfer coefficient in a cylinder wt constant heat flux cdf_user Main CFD Forum 4 May 7, 2012 06:04
Please check out my parallelized udf code aleisia Fluent UDF and Scheme Programming 0 June 10, 2011 17:16
Code for diffusion on the surface of a sphere Vena Pearl Bongolan Main CFD Forum 0 July 14, 2006 18:59
CFX 5.5 Roued CFX 1 October 2, 2001 17:49
Code with reliable free surface capability in a rotating system Subhasish Roy Choudhury Main CFD Forum 1 September 4, 1998 19:47
