Rep Power: 13 ![]() |
I have problems matching the Trimmed Cell Mesher and Prism Layers. The thickness of the Prism Layer is not constant and interrupted over the geometry. Although I tried several settings concerning Prism Layer Thickness enhancement, Base Size reduction and Minimum Surface Size enhancement I couldn't fix the problem. Does anyone has an idea how to solve this problem? or Does anyone know which standard values work fine for Trimmed Cell Mesher and Prism Layers? Best regards, Jack |
KHB
Rep Power: 16 ![]() |
If you can give a better description maybe some picture of your problem, that will help us in understanding your problem
Hello Lava12005,
attached you can find a picture of my problem. ![]() Best regards, Jack |
kw
Rep Power: 14 ![]() |
In your prism layer meshing model try decreasing the layer reduction percentage, increase boundary march angle, and specify near core layer aspect ratio.
Thank you Kasey for your answer,
I already tried your ideas, but it didn't succeed. The solution is to choose an extremely low base size and adapt the other sizes (e.g. surface sizes etc.) Best regards, Jack |
[ICEM] Large elements after creating prism layers | khoopes | ANSYS Meshing & Geometry | 4 | June 17, 2013 13:05 |
[ICEM] width of prism-layers in unstructured grids | Peter2010 | ANSYS Meshing & Geometry | 12 | February 25, 2013 06:02 |
[ICEM] Can't create prism layer on 2D extruded mesh | PedroC | ANSYS Meshing & Geometry | 19 | April 19, 2011 20:48 |
Prism with anisotropic trimmed mesh | fastwave | STAR-CCM+ | 1 | May 9, 2010 10:29 |
Icemcfd: Preventing prism inflation collisions? | Joe | CFX | 1 | July 31, 2007 09:13 |
