Problems in velocity inlet
Old   July 18, 2013, 16:27
Default Problems in velocity inlet
shoumo
amarjogot is on a distinguished road
Hello everyone. I am just having some problem with my model. My model is a cylinder (as shown in the figure). It has two different velocity component (one tangential and one radial). Can any one please tell me how can I input them in my model. Thanks in advance for your help.
Zoheb
amarjogot is offline   Reply With Quote
Old   July 23, 2013, 10:23
siara817's Avatar
siamak rahimi ardkapan
siara817 is on a distinguished road
You need to generate a local coordinates at the middle of your inlet and build a field function for each component (in x, y and z directions) of the velocity.
Good luck
Siamak
siara817 is offline   Reply With Quote
Old   July 23, 2013, 13:31
shoumo
Thank you very much for your help. I was trying to follow your suggestions, but still having some problem. I wrote my radial and tangential components as follows: 0.508*(position[2]^0.143 and .292*(position[2]^0.143. I got two errors. first it was not taking the power (^0.143) part. Showing some syntax error. Then when I removed this (although not right), it showed me some different errors.
error: unable to compute field function: radial velocity (radial velocity)
Cannot resolve function $${position}: "position" not defined.
Old   July 23, 2013, 16:33
siara817's Avatar
For position and scalar properties you should put just one dollar sign.
Please search in the help of STAR-CCM : user defined field function or programming reference. Then you will find out how to write power and so on
Good luck
Siamak
Old   July 25, 2013, 02:48
shoumo
Thank you very much for your assistance. I will try to use your idea and will let you know definitely.
cylinder domain, velocity components
Inlet patch problems martyn88 OpenFOAM Running, Solving & CFD 6 April 21, 2017 19:34
Why we normally provide velocity at inlet and pressure at outlet for pipe flow? p07ip705 Main CFD Forum 3 August 3, 2012 06:53
inlet velocity BC ahsan FLUENT 3 July 22, 2009 05:17
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 03:13
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 06:59
