July 11, 2013, 02:44 |
urgent help about cluster
siamak rahimi ardkapan
Rep Power: 18 |
Hi everybody,
I need to submit a star-ccm job to a cluster, but I do not know how to do that. The job should be submitted to slurm.
Good luck Siamak |
July 11, 2013, 09:49 |
Ryne Whitehill
Rep Power: 19 |
Sorry, never dealt with slurm.
Have you tried contacting cd-adapco? Generally they have been very responsive to questions like this for me. |
July 11, 2013, 16:31 |
Rep Power: 18 |
Thank you rwryne, I think the issue is mainly related to writing the commands in LINUX.
Good luck Siamak |
July 12, 2013, 02:04 |
I run my thesis in a linux cluster. Maybe this can help you: /opt/CD-adapco/StarCCM7.06.012/star/bin/starccm+ -rsh ssh – server –on 195.251.126.227:3,195.251.126.225:3 /media/shared/sims/pipe_porous.sim The above is the commands in the linux. I connect via ssh protocol. Also all the clusters must look on the same file, I'm using samba for that. I hope it helped.. Yours, rick |
July 12, 2013, 04:38 |
Rep Power: 18 |
Thank you rick,
I wrote the following batch file. what do you think is the problem? #!/bin/sh ### ### Job name #SBATCH --job-name=threephase ### Name of queue to submit to #SBATCH --time=40:00 ### Number of nodes required for the job #SBATCH --nodes=2 ### Number of processor cores #SBATCH -n 8 ### Amount of memory per core #SBATCH --mem-per-cpu=12000 ### The actual job execution cd /user/siara817/cfdfiles/threephasestest /pack/STAR-CCM+/starccm+5.02.010 -nodisplay -r threephasestest Thank you again Siamak |
July 12, 2013, 05:19 |
Oliver Lauer
Rep Power: 17 |
What happens, if you use your command? Does it work at all? I am not sure about option '-r' but have never used it.
What I would use is option -np 8 for use of eight processors |
July 12, 2013, 05:25 |
Rep Power: 18 |
Thanks Oliver,
It gives a Job ID but when I check the job, there is no information, i.e. there is a fail. Exactly, I have doubt about the last part. my cfd file is in user/siara817/cfdfiles/ and the cfd software is located in /pack/STAR-CCM+/starccm+5.02.010 I do know if it is the correct way of asking the SLURM to call STAR-CCM to run the file. |
July 12, 2013, 06:19 |
Oliver Lauer
Rep Power: 17 |
Hm,
in my opinion your last line should look like /pack/STAR-CCM+/starccm+5.02.010/star/bin/starccm+ -np 8 -batch threephasestest to start a running server on 8 procs. Probably you could add a " > output.log" to the line to have the output of CCM+ directly written to your folder. In this file you could also see the id of your CCM+ server process. BTW, ccm+5.02 is from April 2010, current version is 8.04 |
July 14, 2013, 02:22 |
#9 |
Rep Power: 18 |
Thank you Oliver, It seems there is a problem in the server of Cluster.
Good luck Siamak |
Making a Cluster with servers at different locations? | Mobz | OpenFOAM Programming & Development | 1 | February 27, 2013 17:16 |
Parallel rerun in cluster | Andy_bm | OpenFOAM Running, Solving & CFD | 4 | November 27, 2011 07:16 |
Parallel cluster solving with OpenFoam? P2P Cluster? | hornig | OpenFOAM Programming & Development | 8 | December 5, 2010 16:06 |
How to install the OpenFoam in the cluster. Please help me! | flying | OpenFOAM Installation | 6 | November 27, 2009 03:00 |
Linux Cluster Performance with a bi-processor PC | M. | FLUENT | 1 | April 22, 2005 09:25 |
