July 8, 2013, 11:14 |
Questions to Surface to Surface Radiation
Rep Power: 13 |
hi @ all,
i never used radiation in star cmm+ and the tutorials do not exactly cover my problem, so i thought you could help me i want to simulate an crucible partly filled with molten aluminium (picture attached) this partly filled state forces me to consider radiation because the air in the upper part of the crucible is an pretty good isolation between the liquid aluminium and the first/fourth layer of the walls in the upper part without heat radiation so how do i do this? i only want to simulate the heat radiation from the liquid aluminium through the air to the first/fourth layer of the walls in the upper part of the crucible heat radiation in the rest of the crucible is taken into consideration by heat resistance and heat transfer coefficents emissivities of liquid aluimium and the first/fourth layer are know to me so i thought i activate the radiation only in the air physics and assign the emissivities to the corresponding interfaces is this the correct approach? any other ideas? any help would be great thanks |
July 15, 2013, 07:43 |
Rep Power: 13 |
please can somebody help me?
July 15, 2013, 07:55 |
siamak rahimi ardkapan
Rep Power: 18 |
Hi
If you use S2S and then gray thermal, then you do not consider the radiation effect on the fluid ( aluminum). You have a hot surface that will radiate the heat to the upper parts. Therefore, seems to me that you already have the case you need.
Good luck Siamak |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
[snappyHexMesh] Layers don't fully surround surface | EVBUCF | OpenFOAM Meshing & Mesh Conversion | 14 | August 20, 2012 04:31 |
[ICEM] Automatic mesh generation script surface intersection problem | stuart23 | ANSYS Meshing & Geometry | 0 | May 13, 2011 01:10 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 12:43 |
Reflection of solar radiation on sea surface | lei | FLUENT | 0 | January 17, 2003 04:44 |
