Suspected division by zero on velocity reported by point probe |
June 27, 2013, 00:14 |
Hi All,
I am doing a mesh refinement study with a DFBI overset mesh and am trying to get velocity values (i,k) via two maximum reports vs. iteration. I picked a point in the region of interest created a derived part, created two maximum reports getting the i velocity and k velocity at that point, created the monitors for each report, and then put them into an XY graph plot. It works fine except that there are time when the values seem to be divided by zero for 4 or 5 iteration and some as long as about 40 iterations. Is this a bug in the point probe, maybe a cell to point probe alignment problem? I would expect this behavior early in convergence, but not at the end. Thanks, Dave |
July 4, 2013, 03:16 |
Here is an image of the problem
I attached a plot of two points on a 2.5D mesh one behind the other. Both points appears to get a divide by zero; one more than the other.
hull-1ms-8p0H-67mlambda-50mh-2.5D_Fluid Velocity at both points 0,0 1_0.25 -5.jpg |
mesh refinement study, point probe, starccm+ |
Probe for X or Y velocity | msrinath80 | OpenFOAM Running, Solving & CFD | 29 | July 22, 2015 18:46 |
Why: Point velocity always monitored as 0.0? | Tanhn | FLUENT | 3 | February 6, 2007 10:47 |
How to get velocity data at some point in domain | sawa | FLUENT | 3 | February 28, 2005 07:03 |
udf to output velocity at some point | Jun | FLUENT | 4 | August 19, 2003 14:43 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
