Problems with mass imbalance
Old   May 23, 2013, 02:26
Default Problems with mass imbalance
Tobi
kannstmasehn is on a distinguished road
Hi all,
I want to check the mass imbalance of my calculation. It's a cyclone separator with Air and as the lagrangian phase H2O. I activated the option boundary sampling in the lagrangian phase.
My boundaries are inlet, outlet, wall and I have the lagrangian phase. What kind of report do I have to choose to display the mass imbalance? And what vector and parts do I have to select?
regards
kannstmasehn is offline   Reply With Quote
Old   July 23, 2013, 10:25
siara817's Avatar
siamak rahimi ardkapan
siara817 is on a distinguished road
You can use sum report, then select the boundaries in parts and select the field function of boundary mass transfer.
Good luck
Siamak
siara817 is offline   Reply With Quote
Old   July 25, 2013, 20:21
malu
malfrienz is on a distinguished road
why does the following error occur?
"An internal error has occured. please contact your support.....
Attempt to access unallocated massImbalance storage in cells in Body 1"
I get this error when i try to run a previously saved run. How can we overcome this error?
Thanks
malfrienz is offline   Reply With Quote
Old   July 26, 2013, 04:38
siara817's Avatar
The mass imbalance function calculate the imbalance for each cell. Have you removed any cell?
Anyway, as I told you, if you want to see how is the mass imbalance ( continuity), a Sum report will help you.
Good luck
Siamak
domain imbalance for enrgy equation happy CFX 14 September 6, 2012 02:54
mass imbalance in wind tunnel problem Robert2011 FLUENT 0 January 25, 2011 07:46
What is mass imbalance? thecfduser FLUENT 4 December 8, 2009 03:56
Integral of mass Imbalance drops with time TfG FLUENT 0 April 3, 2009 12:38
Mass flux - Axisymmetric problems. JSM FLUENT 0 May 3, 2007 00:56
