Histogram on a selected volume, Droplet diameter profile |
May 17, 2013, 07:12 |
Rep Power: 15 |
Hi everybody
I am currently computing an injection of water droplets into a cylinder pipe. I am trying to plot the droplets diameters profile. For this purpose, when plotting the profile for the entire pipe, I am using the Plot>Histogram option. I am then getting the histogram representing my droplet diameter distribution on all the pipe (actually, of the Lagrangian Phase, as I must select the Lagrangian phase as the part to be plotted). I have several questions concerning Histogram and field functions: 1/My concern is the following: I wish to plot such histogram only on a small part of my pipe, not the entire pipe. Does anyone know how to make a volume selection in order to plot the histogram of field functions values restricted only to that volume? 2/ One solution I tried was to define afield function defined only on a part of the pipe ( for example ($$Position[0] < 0.5) $ParticleDiameter : 0) is defining a new field function with the droplet diameters from X=0 to 0.5, and putting the diameter to 0 for droplets situated at the end of the pipe. However, when I will plot, it will report also n droplet of diameter 0, which is not really stisfactory. 3/ I was thinking to first export the Particle Diameter to a Table, to then extract the data (Diameter and Particle Count) for the desire position, but I do not success to make it work. If someone have some hint to do this? 4/ On additional question is about the field function ParticleCount. What does it represent exactly? When I am reading the values, it shoes for example, 0.5. However, when I plot the histogram weightin the droplet diameter with the DropletCount function, the count can go up to 30 (which I like) When I export a histogram table, it names ParticleCount as 'ParticleCount - average", with value 0.5, then 'ParticleCount - sum' and gives the value 30, and finaly, I can get a 'ParticleCount - accum' which is the cumulative sum of the droplet count for each bin. I am interested in getting 'ParcticleCount - sum', but when you export the field function, you are getting the value of 'ParticleCount - average'. Does anyone knows how to get directly access to ParticleCount - sum? Thanks a lot for any help |
droplet diameter, field function, histogram |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
droplet absorption diameter | Claudia | CFX | 4 | April 2, 2010 07:14 |
Post Processing (droplet volume calculation) | Khalid Rahman | FLOW-3D | 3 | March 13, 2009 14:57 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
Miminum diameter of droplet | bk | Siemens | 0 | July 12, 2005 07:54 |
