FAN simulation with inhomgen Temperature
Old   May 7, 2013, 09:44
Default FAN simulation with inhomgen Temperature
Markus
Shark is on a distinguished road
I simulate a fan with an inhomogeneous temperature source in front of it. The rotation of the fan is simulated with MRF and also as a rigid body motion.
The MRF simulation shows that the heat is transferred against the rotation direction of the fan. The unsteady simulation transports the heat in the right direction.
So I am searching for the factor of this behavior, but until now I couldn't find a mistake in the simulation and some literature about this problem of the MRF.
Someone knows this problem and/or knows some literature about this behavior?
Thanks
Markus
Shark is offline   Reply With Quote
Old   May 8, 2013, 10:24
siara817's Avatar
siamak rahimi ardkapan
siara817 is on a distinguished road
Can you put a picture from your domain.
Have you checked if the gravity direction is correct?
Have you selected air as an ideal gas/real gas?
Good luck
Siamak
siara817 is offline   Reply With Quote
fan simulation, multiple reference frame, rigid body motions
Query regarding temperature distribution in Solidworks flow simulation syarif FloEFD, FloWorks & FloTHERM 3 February 27, 2013 06:22
Simulation and Optimisation of centrifugal fan 3D to 2D eRzBeNgEl STAR-CCM+ 0 January 31, 2013 14:21
Temperature depending on x,y as boundary condition in Steady-state Thermal simulation FluidCFD CFX 6 December 3, 2012 12:01
high temperature in a coupling simulation sheintz STAR-CCM+ 3 September 30, 2010 14:56
why is solid temperature same as fluid temperature on flow simulation ? qihongming FloEFD, FloWorks & FloTHERM 0 May 26, 2009 09:57
