February 20, 2013, 16:34 |
Solution Diverging with Trimmer Mesh
rietuk
Rep Power: 13 |
I am simulating nozzle flow. Initially I used a polyhedral mesh and the solution converged but the mesh was not aligned with the flow. I then used a trimmer mesh, firstly with volumetric control to increase the resolution along the jet centreline but the solution diverged. This is with the same boundary conditions and initial solution based on the polyhedral mesh and a further simulation starting from no solution. I thought it was an issue with the volumetric control therefore started again, used a trimmer mesh, refined by field function. The mesh looked good but again the solution diverged. Are there any obvious reasons why a refinement of trimmer mesh would cause the solution to diverge? Is there another way to refine my mesh along the jet centreline? Thanks for your help |
February 20, 2013, 17:15 |
siamak rahimi ardkapan
Rep Power: 18 |
Have you tried using 1st order for your solvers? If you go to continua/physics/models and click on each model to change them to first order.
Good luck Siamak |
February 20, 2013, 17:36 |
rietuk
Rep Power: 13 |
Just changed the solvers to 1st order and the solution still diverges after about 200 iterations Is there anything else I can try? Thanks fory your suggestion |
February 23, 2013, 07:06 |
Arjun
Rep Power: 34 |
February 23, 2013, 07:56 |
rietuk
Rep Power: 13 |
How do I enable green gauss grads? Thanks |
February 23, 2013, 08:50 |
Arjun
Rep Power: 34 |
February 25, 2013, 18:22 |
rietuk
Rep Power: 13 |
The green gauss grads didn't stop the solution diverging. Is there anything else I can try? The solution with refinment of a polyhedral mesh converges. Is there something wrong with the refinement of a trimmer mesh? Thanks again |
February 26, 2013, 04:34 |
Rep Power: 18 |
The other way is to reduce the under-relaxation factors for the solvers.
However it seems that your problem is meshing problem. check the quality of your mesh. under Representation button, right click on the volume mesh and click repair. Then check some parameters to see how is the quality. Also you can go to the mesh button at the toolbar and click on the Diagnostics. See how is the quality of your mesh.
Good luck Siamak |
February 27, 2013, 05:50 |
#9 |
rietuk
Rep Power: 13 |
I have run the diagnostics but do not really understand the result. Please could you help me decipher the results? Are there any problems with the mesh?
Thanks very much Boundaries of region Region 1: Boundary Supersonic.NozzleEnd: 4990 faces (725 triangular, 3931 quadrilateral, 334 polygonal) Extents: x: [-1.7199441265e-002, 1.7199414698e-002] m y: [4.7600000000e-002, 4.7600000000e-002] m z: [-1.7199994832e-002, 1.7199489998e-002] m surface area: 2.5046555675e-004 m^2 maximum boundary skewness angle = 4.4404441833e+001 deg in cell with pro-STAR Cell ID 1462007 Boundary Supersonic.BackWall: 10335 faces (146 triangular, 9641 quadrilateral, 548 polygonal) Extents: x: [-2.2472767801e-001, 2.2499997918e-001] m y: [-1.8503454204e-017, 1.7347234760e-018] m z: [-2.2492098468e-001, 2.2496523856e-001] m surface area: 1.5728729963e-001 m^2 maximum boundary skewness angle = 1.6066276550e+001 deg in cell with pro-STAR Cell ID 1262014 Boundary Supersonic.Wall: 1858 faces (713 triangular, 1003 quadrilateral, 142 polygonal) Extents: x: [-6.6533111398e-001, 6.7499995615e-001] m y: [-1.8503454204e-017, 1.5000000000e+000] m z: [-6.6627009729e-001, 6.6488350765e-001] m surface area: 4.3908433914e+000 m^2 maximum boundary skewness angle = 7.3802474976e+001 deg in cell with pro-STAR Cell ID 1282845 Boundary Supersonic.Outlet: 1244 faces (14 triangular, 1092 quadrilateral, 138 polygonal) Extents: x: [-6.6533111398e-001, 6.7499995615e-001] m y: [1.5000000000e+000, 1.5000000000e+000] m z: [-6.6627009729e-001, 6.6488350765e-001] m surface area: 1.3925027847e+000 m^2 maximum boundary skewness angle = 6.8445991516e+001 deg in cell with pro-STAR Cell ID 1246219 Boundary Supersonic.Inlet: 8023 faces (178 triangular, 7483 quadrilateral, 362 polygonal) Extents: x: [-1.7199999419e-002, 1.7199614628e-002] m y: [-2.1684043450e-019, 1.6927399783e-018] m z: [-1.7199998728e-002, 1.7199553642e-002] m surface area: 9.2931446852e-004 m^2 maximum boundary skewness angle = 2.8490482330e+001 deg in cell with pro-STAR Cell ID 2254323 Boundary Supersonic.NozzleInner: 93587 faces (7212 triangular, 83537 quadrilateral, 2838 polygonal) Extents: x: [-1.7199999419e-002, 1.7199993944e-002] m y: [4.1204656301e-021, 4.7600000000e-002] m z: [-1.7199999943e-002, 1.7199974894e-002] m surface area: 4.9826093018e-003 m^2 maximum boundary skewness angle = 4.2953495026e+001 deg in cell with pro-STAR Cell ID 1467600 Boundary Supersonic.NozzleOuter: 40232 faces (3034 triangular, 36895 quadrilateral, 303 polygonal) Extents: x: [-1.9199974328e-002, 1.9199978807e-002] m y: [2.5393132223e-021, 4.7600000000e-002] m z: [-1.9199999803e-002, 1.9199985455e-002] m surface area: 5.7216174901e-003 m^2 maximum boundary skewness angle = 3.9444232941e+001 deg in cell with pro-STAR Cell ID 2211770 Region Region 1: 5782 tetrahedral cells 1994876 hexahedral cells 122792 wedge cells 84 pyramid cells 131026 polyhedral cells 2254560 cells total 6760402 interior faces (142158 triangular, 6438996 quadrilateral, 179248 polygonal) 2408370 vertices Extents: x: [-6.6533111398e-001, 6.7499995615e-001] m y: [-1.8503454204e-017, 1.5000000000e+000] m z: [-6.6627009729e-001, 6.6488350765e-001] m Maximum interior cell index delta: 1637064, average: 5.4672870859e+002 Maximum cell face index delta: 4977273, average: 1.2919498470e+003 Volume range: [6.4683247501e-015, 1.1530551128e-003] m^3 Minimum volume in cell with pro-STAR Cell ID 1469238 Minimum distance between centroids of neighbor cells = 1.3194574657e-005 between cells with pro-STAR Cell ID 1967702 and 1967701 Maximum skewness angle = 7.4639190674e+001 deg in cell with pro-STAR Cell ID 1282859 Face validity: Minimum Face Validity: 1.0000000000e+000 Maximum Face Validity: 1.0000000000e+000 Face Validity < 0.50 0 0.000% 0.50 <= Face Validity < 0.60 0 0.000% 0.60 <= Face Validity < 0.70 0 0.000% 0.70 <= Face Validity < 0.80 0 0.000% 0.80 <= Face Validity < 0.90 0 0.000% 0.90 <= Face Validity < 0.95 0 0.000% 0.95 <= Face Validity < 1.00 0 0.000% 1.00 <= Face Validity 2254560 100.000% Volume Change: Minimum Volume Change: 2.432260e-003 Maximum Volume Change: 1.000000e+000 Volume Change < 0.000000e+000 0 0.000% 0.000000e+000 <= Volume Change < 1.000000e-006 0 0.000% 1.000000e-006 <= Volume Change < 1.000000e-005 0 0.000% 1.000000e-005 <= Volume Change < 1.000000e-004 0 0.000% 1.000000e-004 <= Volume Change < 1.000000e-003 0 0.000% 1.000000e-003 <= Volume Change < 1.000000e-002 249 0.011% 1.000000e-002 <= Volume Change < 1.000000e-001 16796 0.745% 1.000000e-001 <= Volume Change <= 1.000000e+000 2237515 99.244% Maximum boundary skewness angle in region = 7.380247e+001 deg Overall Face Validity: Minimum Face Validity: 1.000000e+000 Maximum Face Validity: 1.000000e+000 Face Validity < 0.50 0 0.000% 0.50 <= Face Validity < 0.60 0 0.000% 0.60 <= Face Validity < 0.70 0 0.000% 0.70 <= Face Validity < 0.80 0 0.000% 0.80 <= Face Validity < 0.90 0 0.000% 0.90 <= Face Validity < 0.95 0 0.000% 0.95 <= Face Validity < 1.00 0 0.000% 1.00 <= Face Validity 2254560 100.000% Overall Volume Change: Minimum Volume Change: 2.432260e-003 Maximum Volume Change: 1.000000e+000 Volume Change < 0.000000e+000 0 0.000% 0.000000e+000 <= Volume Change < 1.000000e-006 0 0.000% 1.000000e-006 <= Volume Change < 1.000000e-005 0 0.000% 1.000000e-005 <= Volume Change < 1.000000e-004 0 0.000% 1.000000e-004 <= Volume Change < 1.000000e-003 0 0.000% 1.000000e-003 <= Volume Change < 1.000000e-002 249 0.011% 1.000000e-002 <= Volume Change < 1.000000e-001 16796 0.745% 1.000000e-001 <= Volume Change <= 1.000000e+000 2237515 99.244% |
trimmer |
Solution on hexa mesh vs solution on tetra mesh | Chander | CFX | 2 | December 10, 2011 10:35 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 15:09 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 10:38 |
