February 16, 2013, 08:42 |
Line Probe Smoothing
anonymous
Rep Power: 14 |
I am having some trouble with the line probe function in Starccm+ and creating a plot from it. I have a turbine blade and on the surface is a line probe starting at the surface and on a vector normal to the surface (shown in the image) 2D_NFC_1f_Mesh Scene 1.png I am then looking to assess the velocity profile in this region so I have created a plot. 2D_NFC_1f_XY Plot 2.png As you can see the plot is not very smooth as some of the cells have a number of line probe points in them and others near the surface have only one. I have used the smoothing function as shown below but there are still issues (at the corner for example at a velocity of 14m/s) so I was wondering if anyone knew of a way to sort this. 2D_NFC_1f_XY Plot 2_smoothed.png I really just want to create a line probe or something and when extracting data only take the value in each cell once and associate that value with the centre of the cell for example not multiple times at different locations in the cell. thanks |
May 21, 2013, 23:36 |
#2 | |
Abdullah Karimi
Rep Power: 16 |
line probe, smoothing, steps |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 03:09 |
8x icoFoam speed up with Cufflink CUDA solver library | kmooney | OpenFOAM Running, Solving & CFD | 42 | November 6, 2012 12:37 |
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 09:48 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 05:26 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
