Overset mesh error
Old   February 10, 2013, 14:56
Default Overset mesh error
Daniele
Caterpillar85 is on a distinguished road
Hello everyone!
I tried to simulate two boats sailing (one in front of the other) in model scale.
The goal is to catch the movements of the two boats, one on the wake of the other.
I setted up two "overset mesh" (one for each boat region) and a "tank" as fluid volume control.
I also setted up two DFBI motion to move the boats in opposite directions and to allow x,z motions (translation and sinkage) and x,y rotations (roll and trim).
The mesh generation is full achieve with about 1M cells, but when I start the computation CCM+ give this error:
"Found Inactive DonorCells in Region "Tank" . This might be due to too fine or too coarse mesh or due to an overlapping of overset regions."
I check the "Overset cell status" and I don't find any error.
Which is the possible error??
Thanks so much
Caterpillar85 is offline   Reply With Quote
Old   February 10, 2013, 22:09
Ryan Coe
ryancoe is on a distinguished road
This is sort of the generic error for the overset mesh module. As of the current release, there's no way to figure out exactly where the mesh is deficient.
From my experience, it generally means that the mesh is too coarse where the overlap is occurring. I haven't found a good way of addressing this systematically, other than just incrementally increasing mesh density.
Good luck!
Ryan
Ps. Can you really simulate this system with only 1M cells?
Ryan
ryancoe is offline   Reply With Quote
Old   February 12, 2013, 06:54
KHB
lava12005 is on a distinguished road
Hmm normally it happens for me when the higher density mesh for resolving the free surface mesh on the domain overlap with the coarser area on the overset. And eventually the interpolation doesn't work.
Try to make sure that no matter what movement you have on the overset box, the overset box always has its finer mesh intersecting with same or coarser mesh resolution on the domain mesh.
And as the error stated, make sure that the two overset meshes are not overlapping with each other.
Hope this helps.
lava12005 is offline   Reply With Quote
Mesquite - Adaptive mesh refinement / coarsening? philippose OpenFOAM Running, Solving & CFD 94 January 27, 2016 10:40
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x Saxwax OpenFOAM Installation 25 November 29, 2013 06:34
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 13:34
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 03:32
