dissolution mass transfer with STAR-CCM+ 7.04
Old   February 5, 2013, 13:35
Unhappy [Solved]dissolution mass transfer with STAR-CCM+ 7.04
yonezawa masahiro
yonemasa7 is on a distinguished road
Does any one calculate the dissolution mass transfer? Could you explain how to do that?
And how to set up with phase model. In this case, I have two liquids. It seems that it is needed to have more components in the manual.
I'm trying to solve Soret effect with methanol-toluene mixture.
I can't choose the option.
I'm using these physic models are as follows;
2D, Eulerian multiphase, gradient, gravity, stationary, laminar, multiphase mixture, multiphase equation of state, multiphase interaction, multiphase segregated flow, and multiphase coupled energy.
Phase models are as follows;
multi-component liquid x2, segregated temperature energy, non- reaction, segregated species, and poly density.
Any suggestions are welcome. Cuz I'm quite new to the phenomena.
Thank you in advance
yonemasa7 is offline   Reply With Quote
Old   February 5, 2013, 16:19
yonezawa masahiro
I have got it by myself!
In case you have the same problem, I will write how to do that.
Once you create new phase interaction node, choose the model "Eulerian continuous-dispersed" and something else you need.
Then, specify "Eulerian continuous-dispersed" and finally you can see the option "Dissolution mass transfer rate".
bye-bye
Old   May 13, 2013, 16:26
Default Need Help on this
Evert
Pgma is on a distinguished road
bye-bye
I'm trying to model a simple mass transfer in STAR CCM+, a simple shape of box contains a combination of solid and liquid and after applying the pressure the liquid will separated, how can I mpdel this process!
Thanks
Pgma is offline   Reply With Quote
diffusion, mass transfer, mixture model, multiphase mixture
mass transfer in ANSYS thipps ANSYS 1 August 29, 2013 12:05
star design - to model heat transfer gagi Main CFD Forum 0 November 11, 2011 02:41
About phase change heat and mass transfer Michael FLUENT 2 February 13, 2011 02:49
free convective and diffusive mass transfer rajani FLUENT 0 July 27, 2005 09:28
Vof, udf and mass transfer panel Jay FLUENT 1 March 15, 2005 01:29
