residuals not converging
Old   December 4, 2012, 02:24
Smile residuals not converging
liladhar
liladhar is on a distinguished road
hi there,
i have an offshore structure(TLP-tension leg platform). when i am running simulation in star ccm+ i am unable to converge the solution. the inial residual for momentum(x,y,z) are high. after reducing the under-relaxation factors also, all in vein.
please help.
liladhar is offline   Reply With Quote
Old   December 4, 2012, 22:11
John
nomad is on a distinguished road
Do you have any plots to show? What is your problem setup? Is it a steady/unsteady sim?
nomad is offline   Reply With Quote
Old   December 13, 2012, 01:53
Default residuals not converging
liladhar
hi there,
i am attaching the residual graphs.
plz help
Old   December 13, 2012, 04:06
siara817's Avatar
siamak rahimi ardkapan
siara817 is on a distinguished road
It seems the problem is because of low mesh quality.
But before that go to Continua/physics, click on the flow and turbulence model. Change them from second order to first order. If it started converging, let converge until getting uniform horizontal lines, then again change to second order.
Hope it will work
Good luck
Siamak
siara817 is offline   Reply With Quote
convergence, residuals., tlp
Solution not converging, but oscillating residuals around a constant value Irene FLUENT 2 February 7, 2012 12:55
k and epsilon residuals not converging NISHIKANT TAMRAKAR FLUENT 9 October 11, 2011 11:47
Converging the Turbulent Equation Residuals Josh CFX 0 November 29, 2010 20:02
Converging then Diverging Residuals??? Erika Johnson FLUENT 8 September 19, 2006 11:45
Convergence - scaled vs unscaled residuals HS FLUENT 1 November 7, 2005 06:45
