matching pressure drop with test set up
Old   November 13, 2012, 23:43
Default matching pressure drop with test set up
adam
sieginc. is on a distinguished road
I'm running a simulation that has a lower pressure drop than what I'm reading from a similar experimental test set up. In the test set up, there is a fan at the inlet whereas in the simulation the inlet is just velocity with uniform flow. I'm guessing the higher losses in the experiment are due to fan swirl, because all the dimensions between the two are exact. How do I account for the extra DP in the experimental set up caused by the fan? I have tried messing with the turbulence intensity and other settings but that had zero influence.
sieginc. is offline   Reply With Quote
Old   November 14, 2012, 05:01
azt
allan thomson
azt is on a distinguished road
Hi
You can use a porous region close to the exit of the domain and successively reduce the pososity until you get the desired pressure drop between the inlet and outlet.
allan
azt is offline   Reply With Quote
Old   November 15, 2012, 20:13
abdul099 is on a distinguished road
It's also a matter of how much your simulation results differ from the experimental ones. Many people either overestimate the accuracy of simulations or underestimate the effort needed to produce "exact" results.
Also, don't bother too much with comparing experimental results with simulation results unless you REALLY know what's going on in the experiment. I've seen too many people bothering about the difference between simulation and experiment - but they didn't even know the limitations of the experiment and how big the experimental error was (and believe me, experiments can be as wrong as simulations).
Nobody trusts a simulation - except the guy who did it.
Everybody trusts an experiment - except the guy who did it.
Of course, that doesn't necessarily mean your simulation is right - just try to simulate exactly what you've been measuring.
We do three types of jobs here:
GOOD, FAST AND CHEAP
You may choose any two!
abdul099 is offline   Reply With Quote
[ICEM] ICEM Scripting Issues tylerplowright ANSYS Meshing & Geometry 33 September 27, 2021 17:35
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 04:01
pressure drop jay Main CFD Forum 1 September 24, 2008 10:27
How to set environment variables kanishka OpenFOAM Installation 1 September 4, 2005 11:15
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 14:19
