StarCCM+ Command line options and Macro execution
Old   October 23, 2012, 14:40
Default StarCCM+ Command line options and Macro execution
isidp is on a distinguished road
Hi to all,
I've written a Star-CCM+ Macro that uses a jar library. From the Star-CCM+ GUI it works because I've set the "User Macro classpath" (Menu Tools=>Options=>Environment).
Now, I want to run the same macro from command line. Into documentation there is a command line option "-classpath" that should overried the "User macro classpath", but it doesn't work. Obviously, I've removed the "User macro classpath" option
The command line is:
starccm+ -classpath "C:\libs" -m MyMacro.java simulation
but it gets an error window: package xyz does not exist ... cannot find symbol. It seems that it cannot find the jars and that the classpath setting from command line fails.
Thanks
isidp is offline   Reply With Quote
Old   October 23, 2012, 15:30
sgrshukla is on a distinguished road
classpath is the location of class library used for the macro. where your .jar files if located in different directory.. If you just recorded macro then just run it without providing classpath.
sgrshukla is offline   Reply With Quote
Old   October 24, 2012, 05:29
Hi sgrshukla,
I've written the macro and it uses an external jar. I need the classpath to specify the jar location.
So, from GUI it works (I've added the classpath to "User macro classpath"), but it doesn't work from command line with the option "-classpath"
Old   October 24, 2012, 14:42
abdul099 is on a distinguished road
Linux or Windows?
We do three types of jobs here:
GOOD, FAST AND CHEAP
You may choose any two!
abdul099 is offline   Reply With Quote
Old   October 24, 2012, 14:44
Hi abdul099,
Now, I'm working on Windows operating system.
Old   October 24, 2012, 18:04
I think you also want to add "-batch" in command line before macro name and filename.
Old   January 29, 2013, 04:21
Default Star CCM+ Unable to access JAR in Linux Envi
aparajitha
aparajitha is on a distinguished road
Hi All,
I wrote a mcro using some supporting JAR.
I have added the both JAR path and macro path in "User Macro ClassPath" Settings also.
But my macro is unable to find the '.JAR' i have used.
Iam using Star CCM+ 7.04 in linux environment.
Kindly help me.
Thanks,
aparajitha
aparajitha is offline   Reply With Quote
Old   January 29, 2013, 04:39
Smile [SOLVED] StarCCM+ Command line options and Macro execution
I'm going to describe the solution to my initial post and some tricks that I've faced. Solution is for Windows Operating System but It can be easily adapted for linux environment.
It's possible to override macro libraries path (classpath) from command line only with "-batch" option otherwise you should set library path from GUI into "User Macro ClassPath" window. It's an example of command line macro execution:
starccm+ simfile.sim -batch MyMacro.java -classpath "C:\libs"
Finally, classpath string (e.g. "C:\libs") hasn't the "\" char at the end; I've gets some errors terminating path with blackslash as last character.
Thanks to all.
Old   January 29, 2013, 06:00
aparajitha
Hey,
It's in Linux environment..
Also, starccm+ command is giving me error: "Command not found"
Iam giving this command from path where ccm is installed.
Thanks in advance..
Macro Heat Exchanger not selecting (Please help!) zdeth FLUENT 2 September 11, 2012 14:52
